2009 Audi A3 with CAN issues
I've read through your forums and not been able to directly find the problem I'm having.
I have two issues. First issue Passenger rear left door controller is not on the can network but is powered. I have tested the left door controller on the right door and it functions correctly. The window goes up and down with the window switch in the rear door but does not function from the drivers door. Also it does not lock and does not show open or closed.
Second issue is the driver door impact sensor is in open circuit. I've tested the sensor from the drivers door front on the passenger door left and it functions fine.
Below is the auto scan for my car. I believe the issues are the DTC's from the immobilizer and CAN network but i'm unsure what processes I should take to correct.
Thank you very much for your help,
Brett Capiau
CDS Version: Release 11.11.6
Data version: 20121223
Monday,26,August,2013,14:24:43:06363
Chassis Type: 1K0
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 52 56 62 72 77
VIN: WAUHF68P89A020944 Mileage: 86880km/53984miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Not registered 0001
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 8P0 907 115 AG HW: 8P0 907 115 Q
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: AUX7Z0H6FNE0KQ
Coding: 0103010A1C070160
Shop #: WSC 06314 000 00000
VCID: 77F7430606D59FA0111
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 051 C HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1802
Revision: 04843012 Serial number: 00000807011772
Coding: 0000020
VCID: 132F1796326D53808D9
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 14426012492400FA281406E8921D0041B900
VCID: 75EB490EDCD9EDB003D
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000608 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
VCID: 73EF771612ADF3802D9
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 11
Reset counter: 34
Mileage: 84085 km
Time Indication: 0
Date: 2012.10.15
Time: 18:01:22
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 P HW: 8P0 907 279 P
Component: Bordnetz-SG H53 2902
Revision: 00H53000 Serial number: 00000008618541
Coding: F1AC3F8980141380FF00001C0080000000384E056411400300 1800000000
Shop #: WSC 06314 123 08192
VCID: 4A91CAF225A7D248BEF
Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150568
Shop #: WSC 06314
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 122
Reset counter: 104
Mileage: 85496 km
Time Indication: 0
Date: 2013.07.22
Time: 00:18:00
Freeze Frame:
ON
Voltage: 13.85 V
OFF
ON
OFF
OFF
OFF
01334 - Door Control Module; Rear Right (J389)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 86887 km
Time Indication: 0
Date: 2013.08.26
Time: 13:39:00
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 K HW: 8P0 959 655 K
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 30314239304130303033554A304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4A91CAF2EDA7D248BEF
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB40000774488B-
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB400003E770A6M
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB400003E9C88C%
Crash sensor for front airbag; driver side:
Serial number: 35547RB400003E595A9Z
Crash sensor for front airbag; passenger side:
Serial number: 35647RB400003E593AE$
1 Fault Found:
9443093 - Driver's Side Airbag Crash Sensor
B1017 15 [137] - Open or Short to Plus
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 86887 km
Date: 2013.08.26
Time: 14:03:44
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0014142
VCID: 4183EDDE189111106F5
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 A HW: 8P0 920 932 A
Component: KOMBIINSTR. VDO H15 0820
Revision: D0H15004 Serial number: 2246H004003409
Coding: 0000378
Shop #: WSC 65536 645 1593193
VCID: 3261B212AD37BA88E6F
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K087140156
Coding: ED807F061006022102
VCID: 356B890E5C59ADB0C3D
3 Faults Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 104
Mileage: 86887 km
Time Indication: 0
Date: 2013.08.26
Time: 14:07:46
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 86887 km
Time Indication: 0
Date: 2013.08.26
Time: 14:07:47
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 104
Mileage: 86887 km
Time Indication: 0
Date: 2013.08.26
Time: 14:07:51
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H15004 Serial number: AUX7Z0H6FNE0KQ
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0001213
VCID: 438FE7D6028D03007D9
2 Faults Found:
02071 - Local Databus
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A51AA7285E7F2485EF
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 K
Component: KSG H11 0080
Coding: 1B80228001403F3F0F0FCC8F0477
Shop #: WSC 06314 123 12345
VCID: 448DE4CA07830438443
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674802716011
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0001213
2 Faults Found:
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 Q HW: 8P0 035 186 Q
Component: R Concert2+ H02 0270
Revision: 00H02000 Serial number: AUZ1Z3H8963016
Coding: 0750212
VCID: 4085E8DA139B181860B
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Component: Tuer-SG H04 0040
Coding: 0001176
Shop #: WSC 06314 000 1012544
VCID: 4281E2D21D970A0876F
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 P HW: 8P0 862 335 P
Component: FSE_256x BT H34 0520
Revision: 00000000 Serial number: 00000005004820
Coding: 0001277
End ---------------------------------------------------------------------
© 2013 MicrosoftTermsPrivacyDevelopersEnglish (United States)
Brett Capiau
Chassis Type: 1K0
Coding: 0000020
Revision: 00H35001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 34
Mileage: 84085 km
Time Indication: 0
Date: 2012.10.15
Time: 18:01:22
Freeze Frame:
ON
Coding: 00056595
Shop #: WSC 06314
Coding: 00150568
Shop #: WSC 06314
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 104
Mileage: 85496 km
Time Indication: 0
Date: 2013.07.22
Time: 00:18:00
Freeze Frame:
ON
Voltage: 13.85 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 86887 km
Time Indication: 0
Date: 2013.08.26
Time: 13:39:00
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
Cannot be reached
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 86887 km
Date: 2013.08.26
Time: 14:03:44
Coding: 0014142
Coding: 0000378
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 104
Mileage: 86887 km
Time Indication: 0
Date: 2013.08.26
Time: 14:07:46
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 86887 km
Time Indication: 0
Date: 2013.08.26
Time: 14:07:47
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 104
Mileage: 86887 km
Time Indication: 0
Date: 2013.08.26
Time: 14:07:51
1 Fault Found:
014 - Defective
Coding: 0001213
2 Faults Found:
Revision: 00H15000
Coding: 0001213
2 Faults Found:
Coding: 0750212
Cannot be reached
Coding: 0001176
Coding: 0001277
By chance did you have any work done that would involve disconnecting the battery?
If this was my car and had this many faults, I'd print out the list of TC's and then clear the codes. Then check if they come up at a later date.
I've had false TC's set after replacing the battery and when I had my ECU flashed. After clearing the codes they didn't come up again.
SJGQ5
Q5/SQ5 MKI (8R) Discussion
08-11-2022 06:51 AM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
lmariorod
10-26-2017 11:39 AM
ECS Tuning-Audi
02-04-2016 08:36 AM
