2011 A3 with clutch noise - HELP!
I bought a 2011 A3 Dec 2015 with 43k miles. Noticed right away a noise when the clutch reached the engagement point. This noise generally goes away once the engine warms up but I'm starting to hear it even after the engine has warmed up. A vibration occurs in the clutch pedal at the same time the noise is heard.
Happens in both forward and reverse.
The link below is to a video that captures the sound. Generally the sound is much longer and louder than what's in the video. Pedestrians sometimes turn to look to see what car is making noise.
Needs a new pressure plate and disc, right? What about the DMF? Replace that as well? At $600 USD for the DMF I want to get someone else's opinion before I fix something that's not broken.
Appreciate the replies.
- john
Snoqualmie, WA
- john
Snoqualmie, WA
John,
Sadly, I can't offer any insights to your issue but I have noticed the same sound on my 2012 A3 w/ 75k miles for the last few months. I am wondering if you wound up fixing it and what it took to complete the repair.
Thanks!
Alex
Thanks!
Alex
https://www.youtube.com/watch?v=5Lg3yCB81XY
- john
Snoqualmie, WA
- john
Snoqualmie, WA
Hi Alex,
I never got a second opinion, even from some local shops I had queried.
Anyways I got sick of the noise and in Aug I removed the transmission. The clutch/pressure plate, DMF and release (throw-out) bearing all needed to be replaced.
A little over 13 hours of labor. Really great project and the noise and vibrations are completely gone.
Was a pretty straight forward repair. The only thing that took longer than I expected was disconnecting numerous electrical connectors. Setting the torque on the DMF/crankshaft bolts was also a bit challenging but only because I was using short XZN sockets and was improvising a method to hold the DMF in place.
Best theory I've got is the release bearing started to leak fluid which then got onto the DMF and pressure plate. These surfaces then started to rust which resulted in noise and vibration. Only problem with this is I didn't find any fluid on either the DMF or pressure plate.
In any regard it's a much more enjoyable ride now.
HTH
- john
HTH
- john
cc329
06-24-2004 06:17 AM
dougor
07-07-2003 12:03 PM
kilburn
06-30-2002 10:37 PM
