2015 Audi A3 Map Update
Is anyone still having problems with trying to update there Nav?
I had contacted Audi (month ago at least)and they initially said they were having problems but now its fixed.
I've tried everything including what Ive been able to find on the forum. The download gets to verifying application then locks up. I have to force quit, to get out of the download attempt.
Running Mac OSX El Captain 10.11.2, Java
Any help or thoughts would be appreciated.
Had same issue on my S7, problem was Jave disabled in the Safari options (Apples last update disabled Java in an attempt to force web developers to move away from Java)
If you go into the Safari preferences menu and select: Security-->make sure Enable JavaScript is checked, then go to Plug-in Settings, and select Java from the list and check you have Audi.com as "always allow" under the configured websites list.
Took me 3 days to figure that out!
As an aside - I couldn't get my MMI to update via SD card. If you put the download onto a USD stick, you can update that way also, just select USB as the update source in the relevent MMI menu.
Good luck...
Good luck...
hello i have a s3 2015 Audi S3 and A3 Map update
i just downloaded the new map update for 2015 audi s3 the maps installed right now on car are 2014 maps
i have a sd card 32gb its a .zip file 02110014.zip everytime i try it in the car it says no files i have done everything right what Audi says too do
i have to rename the file? or extension? to .jnp or something else? i did extract all the files into the folder and tried that ....it did not work.
This is P.OING Me right off please help.
thank you.
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
thank you.
I tried USB Flash as well.............no luck, what a pain in the.....
Im not around the corner from an Audi dealer, I guess I may need to make the trip.
Love the car, but this should not be so difficult.
Mrchntmarine
07-26-2018 01:04 PM
SimonBackman
23
04-11-2008 05:44 AM
