A3 Cabriolet window not dropping for door opening/closing
I'm scratching my head with this one, the passenger window doesn't drop the 20mm when you pull either the inner or outer door handle?
I changed the window regulator a few weeks ago and the window drop did work afterwards but one day it just stopped dropping..
I have tried various reset procedures, hold button up and down for 15 seconds, with engine running, ignition on and ignition off, none have reset it. I have also read if the micro switch isn't working you also won't get the interior light to come on but it does light up when I open the door. When I operate the window for one touch drop that doesn't work, you have to keep your finger on the button to fully open or close it.
When I operate the roof, it still goes back and forth as it should but as the other 3 windows drop for the roof to operate the passenger side one doesn't so I drop it manually a little incase it causes an issue, I would assume the window not dropping by itself would stop the roof working as a fail safe?
Any ideas what is going on?
Can anyone fathom out what is wrong with my cars window
scott.klein100@gmail.com
10-13-2022 07:17 AM
Limey Chris
06-12-2005 06:52 PM
