a3 codes
anyone out their have the codes for this model ! lookin for the code for unlocking the car with one touch rather than 2 taps , allso want to make the launch control work ! and anything else you can think up! thanks
Bobby S
Bobby S
Apparently Audi decided to enable Selective Locking on the '07 A3s, so I added the instructions on enabling/disabling it.
There's also no such thing as 'making launch control work'.<ul><li><a href="http://oooo-a3.blogspot.com/2006/06/vag-com-coding-reference.html">http://oooo-a3.blogspot.com/2006/06/vag-com-coding-reference.html</a</li></ul>
the VW TSB you heard about was ONLY for 2007 GTI and GLI,
also this cant be done with vagcom on the GTI's, its not in the eninge ECU, seperate ECU for that smart *** tranny
but try this, at redlight, turn ESP off, shift over to manual, depress brake all the way, then slam on gas, engine will rev to about 4000 before the clutch engages
but youll just get wheel spin
Gldnrkt(GT3076R)
06-14-2006 10:04 AM
JJimbo
02-27-2004 06:29 PM
Allroady DungBeetle
08-30-2003 07:01 AM
