A3 drivers: iPhone voicemail playback over bluetooth work for you?
Any have similar or contradictory experiences to my question over in the B8 forum:
https://forums.audiworld.com/a4b8/msgs/21950.phtml
-A<ul><li><a href="https://forums.audiworld.com/a4b8/msgs/21950.phtml">https://forums.audiworld.com/a4b8/msgs/21950.phtml</a</li></ul>
Re: A3 drivers: iPhone voicemail playback over bluetooth work for you?
My calls work reliably, voicemail does not work. I''d love to know if there is a fix. I have a 2g phone
I believe it was a 'feature' added to the 2.0 iPhone software. Since you had to select bluetooth output while driving to listen to your messages, Apple was concerned this was a safety issue. They are reportedly working on a different way to accomplish this and will add it back in a software update.
When I had 1.0 software on my iPhone I could listen to voicemail through BT on my A3.
Chris
Chris
VM does work with BT under 2.x
The OP is talking about it not working with his Audi BT. It is not crippled by Apple; it works just fine with my Jawbone BT headphone, for example, running firmware 2.2.
-dan
-dan
if it is actually a feature and they crippled it, they crippled it poorly: it still defaults to BT as the audio destination even though it's busted.
it needs to be properly fixed.
baubaulu
A6 (C7 Platform) Discussion
01-31-2016 10:17 PM
gimbal (fight on)
Audi A3 / S3 / RS 3
06-02-2008 09:43 AM
Indyxtype
04-27-2005 11:41 AM
Mr.D-'97 A4q 12v
VAG-COM Discussion
03-20-2003 04:53 PM
