Any reason not to get Open Sky tinted?
The one issue I have with Open sky is the amount of heat it lets in the car due to the sunshades. Any reasons not to get the glass tinted with window film? I'll probably try 30% up top and maybe go lower.
Dave
Dave
Will Window Films Cause Glass To Break?
Glass breaks when stressed. There are five types of stress which may cause glass breakage:
1. Thermal Stress--from absorption of solar radiation.
2. Tensile Stress--from the weight of the glass itself.
3. Mechanical Flexing Stress--from wind.
4. Impact Stress--from flying objects, hail, baseballs.
5. Twisting Stress--from building or window frame sagging or settling.
The first type, thermal stress, is the only one which film may affect. The use of window films will increase the thermal stress on sunlit glass. However, there are also other factors which will increase thermal stress such as: partial shading of windows from overhangs, tightly fitting drapes or blinds, signs or decals on windows, heating and cooling vents directed at glass. In addition, different types of glass (annealed versus tempered, clear versus tinted) have different solar absorption rates and will withstand different degrees of thermal stress.
The window film manufacturers have recommended film-to-glass tables for use by factory-trained dealer installers. If a consumer is ever in doubt, he/she should request a copy of such guidelines. Listed are some glass types or conditions where the use of a solar control (not clear safety) type of window film is not recommended without extreme caution.
SINGLE PANE GLASS LARGER THAN 100 SQUARE FEET.
DOUBLE PANE GLASS LARGER THAN 40 SQUARE FEET.
CLEAR GLASS THICKER THAN 3/8 INCH.
TINTED GLASS THICKER THAN 1/4 INCH.
WINDOW FRAMING SYSTEMS OF CONCRETE, SOLID ALUMINUM, OR SOLID STEEL .
GLASS WHERE SEALANT OR GLAZING COMPOUND HAS HARDENED.
VISIBLY CHIPPED, CRACKED OR OTHERWISE DAMAGED GLASS.
REFLECTIVE, WIRED, TEXTURED, OR PATTERNED GLASS.
TRIPLE PANE GLASS.
LAMINATED GLASS WINDOWS
Seems like the roof is made of tinted glass thicker than 1/4"<ul><li><a href="http://www.tintguru.com/faqs.htm">http://www.tintguru.com/faqs.htm</a</li></ul>
TRIPLE PANE GLASS.
aTOMic
03-15-2015 07:48 PM
bitjockey (bum)
06-25-2006 02:45 PM
Swank4
04-27-2006 06:27 AM
SpoonPunk
A4 (B7 Platform) Discussion
04-10-2006 12:19 PM
kungfuliu
02-01-2005 02:31 PM
