Audi A3 8L - Heater only blowing warm air, No Cold Air!!!
Hi,
I've recently purchased an Audi A3 8L 1.9TDI 100bhp 51 Plate, thought everything was great
with car except when i turned on blowers for car it was only blowing warm air!
This model doesn't have air con, so in hot days its almost unbearable, has anybody else had
this problem and do you know how to fix it?
Thanks
Thanks
When you enable A/C do you hear a click and a slight change in engine speed? If not, the A/C clutch/compressor is not engaging. Check fuse in panel along side of the dash using your key engaged in slot prying it up and sliding it out. There is a decal on the cover identifying the correct one so try checking/changing it out. If fuse blows again you have either a bad A/C clutch/compressor or both.
paulie04
A4 (B7 Platform) Discussion
9
07-24-2023 01:01 PM
wazza
08-30-2002 08:19 AM
