Audi A3 Vag Codes - Need HELP !!! :))
Hello everyone
Need help with some Vag codes:
Probles:
Address 19: CAN Gateway
Part No: 1K0 907 530 F
Component: Gateway H10 0120
Coding: 3D0F0B42070100
Shop #: WSC 06314
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Address 37: Navigation
Part No: 8P0 035 192 A
Component: RNS-E HIGH EU H70 0450
Coding: 0205717
Shop #: WSC 30899
5 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
00878 - Connection to Speaker Front Left
011 - Open Circuit
00879 - Connection to Speaker Front Right
011 - Open Circuit
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal
Address 77: Telephone
Part No: 8P0 862 335 M
Component: FSE_255x BT H21 0200
Coding: 0011444
Shop #: WSC 00000
1 Fault Found:
004 - No Signal/Communication
Ok, I tried to install and code a multifunction steering wheel, but i'm not able to insert vag codes. I mean...I push recode and then I try to recode...without lucky.
About others errors...I don't know..
Anyone idea?
Probles:
Shop #: WSC 06314
1 Fault Found:
000 - -
Coding: 0205717
Shop #: WSC 30899
5 Faults Found:
011 - Open Circuit
011 - Open Circuit
011 - Open Circuit
Coding: 0011444
Shop #: WSC 00000
1 Fault Found:
Anyone idea?
I guess you didn't write down the orignal coding to go back and start over, do you? And if you post over there mention what version of VAG-COM and what Ross-Tech cable you are using.
Der Kimbo
01-27-2005 04:50 PM
carbonLORD
11-08-2004 06:11 AM
coocoomike
11-20-2002 08:18 PM
