Couple of iPod connection Q's
Will my Dension ICE Link work with the new style concert head unit?
Does the factory iPod connection allow more than 5 playlists?
T.I.A.
T.I.A.
If you plan to have a passenger navigate playlists for you, then that is best done on the iPod itself where you can see what the playlists/artists/song names are ("New Orleans R&B" vs. "No. 4").
Because the head unit display of iPod info is lame or non-existent depending on the adapter and the mode you use, the best solo technique is to have a good playlist which contains everything you might like to hear while driving. Name it something that forces it to the top of the Playlist menu so it is easy to find without taking your eyes off the road. Then if you hit a tune that doesn't fit your mood, just use the steering wheel controls to advance one track.
If those methods appeal to you, then there is no reason to have capability of accessing more than one playlist via the head unit.
-dan
-dan
There isn't any provision in the protocols used to transfer any other information--remember that the iPod adapter essentially make it look like a CD changer to the headunit.
... to sync the display with the iPod so you get correct track numbers within a playlist and running times and also playlist numbers (no text), but it is slow and clunky and I turned it off.
I've got the ipod set up with 5 playlists each of a different style,with about 100 tracks each, works ok you soon get used to which list is which and approx track numbers.
Jason Sowers(rs6's)
04-09-2008 12:28 AM
Nogaro too
09-25-2007 07:58 PM
paulroad
12-15-2005 11:05 AM
