dave, any luck installing the stealth bulbs yet? I searched the...
archive and it seems that you may be able to access the turn signal bulb without having to remove the whole headlight housing. Apparently, there are several screws in the wheelwell which, when removed, offer good access to the bulb (after peeling back some plastic). hopefully, this method is as simple as it sounds. i haven't had a chance to check out this potential route on my car yet, but I'll be checking it out soon. let me know if you've had any luck yet.
