DIY: Euro amber tail lights and Blind spot mirrors. DIY heated mirrors!
Loving both items. Super easy to install each.
<b>MIRRORS:</b>
Installed in a matter of minutes.
1.Push the outside corner of the factory mirror into the mirror shell.
2.Pull out the mirror on the other side. just yank. There is only one snap that you're pulling on.
3.If you have heated mirrors, unplug the harnesses and remember which color goes to which. 4.Plug in your heated mirror connectors if you have the option.
5.Snap the new mirror into the port.
I tested the heat feature and yes it works.
<b>Car's without heated mirrors:</b>
All you need to for heated mirrors, are heated mirrors, or the heated blind spot mirrors and VAG-com. With the computer you can activate the feature.
I will sell my D+P side factory heated mirrors to someone who needs them, email me.
<b>More at bottom of thread on adding heated mirrors with vag-com.</b>
It only took a matter of a few looks before my eyes could figure out what was going on. Non-issue.
<b>Total install time: 5 minutes.</B>
<b>EURO TAILS:</b>
They look sweet, you can tell they're amber even when they're not on.
1.Find your two access doors on the inside off your trunk, one on either side. Flat head to remove. The access door on the P side is tied to the car, you won't loose it. The access door to the D side is not, so be careful.
2.Inside you'll find a 13mm plastic bolt, with a small flat head inside. Use either or to remove, I used a flat head that was wide enough to only sneak in. This made it very tight Tip: this is important b/c you don't want to loose this bolt, if it falls down, you'll be removing your spare tire to get it.
3.Once you get this long bolt untightened, pull it out with a steady hand.
4.Now you can pull the taillight assembly from inside out, then pull the two tabs out (which are on the outside). I took a pic of the rear of the light, so you can see the 3 points. The long bolt, and 2 tabs.
5...Unplug, switch and reinstall your new light. Very easy.
<b>Total Install Time: 10 minutes</b>
<img src="http://i13.photobucket.com/albums/a279/iMryanmac/euro%20tails/IMG_1507.jpg">
<img src="http://i13.photobucket.com/albums/a279/iMryanmac/euro%20tails/IMG_1517.jpg">
<img src="http://i13.photobucket.com/albums/a279/iMryanmac/euro%20tails/IMG_1522.jpg">
<img src="http://i13.photobucket.com/albums/a279/iMryanmac/euro%20tails/IMG_1525.jpg">
<img src="http://i13.photobucket.com/albums/a279/iMryanmac/euro%20tails/IMG_1549.jpg">
<img src="http://i13.photobucket.com/albums/a279/iMryanmac/euro%20tails/IMG_1562.jpg">
<img src="http://i13.photobucket.com/albums/a279/iMryanmac/euro%20tails/IMG_1561.jpg">
<img src="http://i13.photobucket.com/albums/a279/iMryanmac/euro%20tails/IMG_1560.jpg">
In this pic of the blind spot mirrors: I didn't do this on purpose but it shows how effective they are. I was standing practically next to the mirror, with my arm out to take the pic. And you can see my red sweatshirt in the mirror.
<img src="http://i13.photobucket.com/albums/a279/iMryanmac/euro%20tails/mir.jpg">
I must admit, a lot of these installs are cake. headlamp/fog bulp upgrades, euro switch, euro tails, blind spot mirrors, etc, etc. Very easy stuff.
Thanks to DVAG member Bassbiker!
The coding is in the door control modules (42 - driver door, 52 - pass door)
It all depends on what your current coding is. I have the cold wx package and my coding is 1209 for both front doors.
Here's the coding chart from VAGCOM label file for the driver's door:
C00,Door Electronics Driver (J386) Coding
C01,+0000001 - Rear Lid Remote Unlock Button (E233)
C02,+0000002 - Ambient Mirror Illumination
C03,+0000004 - Mirror Turn Signals
C04,+0000008 - Interior Door Handle Illumination installed
C05,+0000016 - Automatic Run active
C06,+0000032 - Mirror Heater installed
C07,+0000064 - Door Exit/Warning Light installed
C08,+0000128 - 5-Door Chassis
C09,+0000256 - Seat Memory installed
C10,+0000512 - Right Hand Steering
C11,+0001024 - Safe-Motor not installed
C12,+0002048 - Pinch Protection inactive
Here's the full label file from VAGCOM website:http://www.ross-tech.com/vag-c...N.lbl
I'd assume that those without the cold wx pack might have a code of 1177
If that is the case, you just add 32 for MIRROR HEATER INSTALLED
Now if your current code is 1209, you're configured to use the mirror heaters, but still not sure if the wiring is all in place within the door to actually supply power to it.
Page 98 of the owner's manual states "Turn the rotary **** to 0"
"Depending on outside temperature and vehicle speed, the mirror surfaces are heated until the ignition is switched off"
No need to push forward on the ****
You can also turn on the heated mirrors by hitting the rear defroster button. Very handy for morning ice removal routine.
<b>MIRRORS:</b>
<b>EURO TAILS:</b>
Amazing (that you go through the effort to revert to amber, a mandatory feature in Eur.)...
while everybody THERE would love to have them all red like here. Crazy world, huh?
I just installed the left aspheric mirror too, nice difference. Easy swap (except, I had to push harder than I felt comfortable to snap it in all the way--it was kind of wobbly, before it really seated right).
Someone is selling a new pair of blind spot mirrors in the classifieds ;-)
<ul><li><a href="http://classifieds.audiworld.com/cgi-bin/classifieds/classifieds.cgi?db=autoparts&website=&lang uage=&session_key=&search_and_display_db_b utton=on&results_format=long&db_id=23329&a mp;query=retrieval">click</a><
90mtl
09-26-2007 06:13 AM
G18
02-27-2003 01:11 PM
