Do A3s leak oil like the 2.8 A6?
Thinking about moving out of the 2001 A6 Avant to a used A3. Do the A3s have any issues like the A6? Oil leaks, suspension, etc.
Other things to look out for in the 06-08.5 models:
1. PCV (extended service warranty campaign)
2. Cracked coolant flange
3. Cam follower/HPFP failure (extended service warranty campaign)
4. Carbon buildup on the valves
5. Thermostat failure
6. AC compressor failure (TSB available but no extended warranty campaign, primarily '06-'07 models)
7. Intake flap motor failure (I believe there is an extended service warranty campaign on this as well)
The 2008.5 and up models switched to the updated EA888 motor which utilizes a timing chain along with a substantial number of additional updates that make is significantly more reliable.
I'm now a member of the A3 club. 2011 S line Monza silver metallic~
Was driving a 2.8 A6, and before that a 1990 100Q. The A3 scares me, it's so fast, lol.
A6 2.8 Canada
04-23-2005 04:50 AM
A6 2.8 Canada
04-22-2005 06:35 PM
