Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Does the DSG take the same fluid as a regular manual tranny? Say 75W-90?
Old 02-14-2008, 05:07 AM
New Member
BAEL's Avatar
Default Does the DSG take the same fluid as a regular manual tranny? Say 75W-90?
I was thinking of swapping out the tranny fluid for Redline 75W-90, as a 6 spd would take. Does it take the same stuff?
Old 02-14-2008, 07:00 AM
MikeSS's Avatar
Default No--VAG has special DSG fluid......
<center><img src="http://www.ecstuning.com/stage/images/dis/4372/600/4372.jpg"></center><p>
Old 02-14-2008, 04:00 PM
New Member
BAEL's Avatar
Default But is that basically tranny fluid for a manual gearbox? I mean, manufacturers have alot of specific
stuff that can be substituted by aftermarket things. Like dealer 502 oil and using Elf, Motul or Lubro-Moly instead of Castrol group III synthetic. The Audi/VW fluid is not a 75W-90 weight I guess then.
Old 02-14-2008, 05:59 PM
qfrog Ti20's Avatar
Default I think the smart money is on just using the proper fluid.
Alternatively maybe have a sample of DSG fluid analyzed for the sake of determining potential alternatives.
Old 02-15-2008, 04:09 AM
MisterJJ's Avatar
Default Wet clutches = Don't risk it!
I believe that the transmission fluid also circulates through the wet clutch assembly. It would be critically important for the fluid to not only have the correct viscosity, but also the correct friction and heat transfer characteristics.
It could be that it was designed to use a standard fluid, but unless you know for sure, I wouldn't risk it.
Old 02-15-2008, 07:56 AM
New Member
BAEL's Avatar
Yeah, I guess so. Ain't worth it. I'll ask the techs, though. Not that they know more than we do
Old 02-15-2008, 10:37 AM
Corrado79's Avatar
Manual tranny oil is for manual gearboxes only, not autos
Old 02-15-2008, 01:13 PM
Junior Member
TurboSlut's Avatar
Don't even start.
Old 02-15-2008, 08:48 PM
qfrog Ti20's Avatar
Default What about center differentials on automatic gearboxes....
Say 01L &amp; 01V?
Old 02-15-2008, 08:55 PM
Corrado79's Avatar
Diff fluid and manual tranny fluid are different (at least on Audis)
Quick Reply: Does the DSG take the same fluid as a regular manual tranny? Say 75W-90?
