Last edit by: IB Advertising
- Audi A3 How to Replace Engine Coolant Temperature ECT Sensor<br>Step by step instructions for do-it-yourself repairs.
Engine Coolant Temperature Sensor
#11
Gordon1976,
I noticed that you made a comment about dropping $2,600 for replacing HPFP and camshaft. Was this on a 2006 A3? If so, know that you should be covered under an extended warranty. It's good for 10years/120,000 miles. There is a reimbursement form you can fill out.
It is for a 2006 A3. Where do I get this reimbursement form from and how do I know I have an extended warranty? I did not buy the car new, it was used, btw. Thanks for your help.
#14
Never mind the prev. post. I called the number and they said I was eligible so all I have to do is send in my paperwork.
Thanks again for the help guys!!!
#15
#16
What year is your car? Many '06 owners are experiencing the "temp gauge stuck on C" problem. The dealer's first inclination is to replace the ECT sensor. Apparently most of these problems are caused by the thermostat going bad. The A3 ECU monitors the coolant temperature and if it doesn't follow a prescribed profile the ECU kills the temperature gauge. If it's reset (or after a couple of days) it will spontaneously start working again but will usually fail again. This happened to me and the only lasting repair was to replace the thermostat.
If you want to investigate further:
http://forums.vwvortex.com/showthrea...2#post72623312
#17
#18
ECS Tuning-Audi
09-03-2015 12:45 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
