Engine or tire noise?
recently, i've been noticing more and more of a noise especially when i am going at a higher speed, it's almost like a rolling noise but doesn't seem to be coming from the tires since the pressures and everything are perfect.
anyone know what it could be?, sometimes i wonder if its the engine that's causing it
and look for uneven wear.
if u don't rotate at 5k you're sol with those horrible tires.
have only 40km on them but the pressure is fine.
Theres cupping or feathering with these tires, which is a well posted issue.
I have the same noise around 80-90km then worse at about 120km.
Belive me its the tires...
I believe it was even listed in the audi care maintenance booklet. I'll double check later. But I'm 100% sure they did the rotation for me. If you requested it, I doubt they'd object.
I plan to put Falken 452 on my original 17-inch wheels for spring/summer and never ride on the P6 tires again.
