Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Exhaust question....................
Old 11-30-2006, 04:10 PM
MuRaN0Daddy's Avatar
Default Exhaust question....................
there was an exhaust thread this week, and a couple people said they were running aftermarket DP/Cat w the stock exhaust.
whats the benefit of doing one before the other, if you can't do them at the same time, performance wise. and what kind of labor am I looking at for install on a DP, or, exhaust.
Thanks guys!
Old 11-30-2006, 04:44 PM
judgegavel's Avatar
Most of your power will come from the DP, still keeps a closer to stock sound
Old 11-30-2006, 04:48 PM
Default Judge, ceramic, or metal.......and another Q............
can I fit a 245/45/17 under my drop?
Old 11-30-2006, 04:52 PM
judgegavel's Avatar
Default Metal will give you more power...
but will cost more, worth it IMHO.
As for the tires I would think you can as long as your running the factory wheel/offset. If you drop down below ET48 you will probably start running into problems.
Old 11-30-2006, 07:20 PM
New Member
CMcLeod's Avatar
MD, you may want to compare weight of a 225 to a 245...the added weight might hurt performance...
Old 11-30-2006, 07:25 PM
New Member
CMcLeod's Avatar
...just checked TireRack...225vs245 Goodyear GS-D3's = 1 lb more for the larger size...
Old 11-30-2006, 07:51 PM
Steve_Ag Arrow's Avatar
Default I was wondering the same thing, also with the apr program.....
can you run their stg2+ software with just the downpipe? I think that would be a sweet setup with a stock cat back. I just want to keep the exhasut fart when I shift too!
Old 11-30-2006, 08:58 PM
Tomasz@Startup's Avatar
Default Simple
A3 exhaust is plenty big. Only reason to replace is to get different sound / look. No power gains.
OEM cat is restrictive, get rid of it and gain real power, but also this will make your car illegal. Replace it with high flow cat, and keep it mostly legal and get some power....
Old 11-30-2006, 09:00 PM
No metal will give you even more power... he he he ATP has one.
Old 12-01-2006, 12:49 AM
crew219's Avatar
Default I am running SII beta with just a downpipe. Another DSG owner followed suit and
has kept his fart.
I love it and the power is immense.
Guess I better do a writeup this weekend.
Dave
Quick Reply: Exhaust question....................
