HELP!!! Oil filter stuck
Today I attempted my first self-service on my A3. It's a 2009 A3 2.0 Quattro DSG with 55k miles. I changed the plugs, air filter and cabin filter, all of which were super easy. I changed oil on my '99 A4 for 5 years and did my research on the A3 (which is hard to find, as all threads I could find refer to the canister type filter). The filter on this model A3 is on top of the engine, next to the oil dipstick. I got the oil drained and attempted to remove the filter, but no luck. Have used both a ratchet with cap type and strap type. There's practically no room around the filter to get a strap type around the base of the filter.
Any ideas? I suspect next step is to fill the engine with new oil and go let a service garage change it... :-(
--defeated
--defeated
That sounds very simple, but the reality is a little different. Welding aluminium is not an easy thing to do, especially in a case like the one mentioned before. However, I assure you that it’s possible and that you can even do it without having months of practice in welding. It’s enough to read one or two guides, like this one authentic welding guides. I’ve been working in this field for some good years and I know what I’m recommend you. The man who is writing those articles is a professional and believe me, not only you, even I have a lot of things to learn from him. A few days of reading and you will be welding like a magician!
If it's not a canister-type where you have to preserve the housing (some Benz-es have these), get a long-ish flathead with a strong shaft (giggity) or a small pry bar and hammer it through the sides of the housing that should give you enough leverage to crack it loose. Shame on whomever over-tightened your last filter. Especially on top, you're not even fighting gravity! 1/4 turn past finger-tight, and oil that o-ring, jeez!
TT-S4 (12-11-2020)
To those who change their own oil and filter.
Make sure to NOT overtighten the new oil filter. Very little torque is needed to seat the filter. Tightening too much will distort the gasket, and that can actually cause an oil leak from the filter itself.
4ringsinutah
06-16-2016 03:28 PM
jonathanfilippi
09-11-2015 07:52 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
