iPod Adapter
#11
The original kit 8E0-051-444 is not the A3 specific kit. The A3 kit is not yet available. If installed as specified in the manual you will disable your SAT radio.
You can modify the 8E0-051-444 kit (as I did) thanks for the LINK props MoroDave...<ul><li><a href="https://forums.audiworld.com/a3/msgs/42459.phtml">My original write-up</a></li></ul>
#12
<ul><li><a href="https://forums.audiworld.com/a3/msgs/46527.phtml">Turns out there's only going to be one iPOD kit, apparently.</a></li></ul>
#14
FYI for anyone else going to order. There's a special outlet price for $6.99 plus if you use this coupon code ( PA145 ), it's FREE shipping!!!
#15
It is important that you have all 10 wires separated...
If you have soldered before this will take you approximately 30 min. I drilled a 1/2 inch hole in the back of felt lined box itself. Pushed the iPod cable through the grommet first (easier this way) and then poked the cable /w grommet through the hole in the back of the box and then seated the grommet.
If you have any questions on the pin-outs, feel free to email me...
Good Luck...
Good Luck...
#17
If i wasnt to just use teh cable already coming into the glovebox I have to use the PIE adapter, otherwise I'll have to plug right into the back of the stero with any other adapter?
HX_Guy
A4 (B8 Platform) Discussion
04-03-2011 09:01 PM
Kareem of Elise
Audi A3 / S3 / RS 3
04-25-2006 10:03 AM
Angus Beef
02-16-2006 07:12 AM
Prok
10-21-2002 04:47 AM
