Loud Noises on high speed
Whenever I drive above 60mph, the noise of the engine or whatever becomes so loud...I took it the dealer and they claimed it's due to the wear of the tire since it's a FWD. Is this really true? If I get new tires, will the noise be gone? Anyone else have the same problem with their 2.0T???
the original tires that came with the car when I bought it 1.5 years ago
i think it's the engine sound, but i'm not sure...the ride is just not quiet like it used to be.
louder than normal tire noise. You can often see or feel such uneven wear, the tire won't look smooth and even or the edges will have a bit of uneven lumpiness.
Tire noise relates directly to speed, proportional and often heard as a whine or drone. It would be louder at speed, and won't quiet when the car coasts in neutral as mechanical engine or trans noise should. Some tire noise problems make more sound upon brake application or even cause mild feedback during braking.
I have no A3 tire experience, yet. Your "car vocabulary" suggests that you might benefit from the aide of another friendly, more knowlegable AW member nearby taking a look and listen to your car for you, someone who is neutral on the problem and your wallet, so that you can decide what next. Where do you live?
