Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Lt turn signal blinking twice as fast as normal
Old 04-07-2013, 12:24 PM
  #11
bcgreen's Avatar
Originally Posted by LWNY
side marker?
Side marker is part of the assembly, so yes it lit.
Old 04-07-2013, 05:48 PM
  #12
LWNY's Avatar
side markers are slightly behind the front wheel well, not inside the front light assembly.
Old 04-08-2013, 06:25 AM
  #13
bcgreen's Avatar
Sorry, I thought the question was directed to the rear of the vehicle.
Old 04-08-2013, 05:17 PM
  #14
bcgreen's Avatar
I have only reflectors on the side, no bulbs.
Old 04-08-2013, 06:02 PM
  #15
record10's Avatar
Why are there no bulbs in your side indicator lamps?????
Old 04-08-2013, 06:33 PM
  #16
MikeSS's Avatar
2010+ models have no side markers on the fender. They're part of the side mirrors.
Old 04-08-2013, 06:43 PM
  #17
bcgreen's Avatar
Correct you are and the side view mirrors are flashing at the normal rate. I've noticed that if I don't apply the brakes or use the lt. turn signal, I don't get the warning indication on the dash board. I wonder how long can I drive before the warning light comes on, in the dashboard. I wonder if there is some connection between applying the brakes and the warning light in the dash. I am just grasping at straws, because this whole thing is not making sense. Everything appears normal except for the warning light and rapid blinking of the lt. turn signal.
Old 04-08-2013, 08:15 PM
  #18
LWNY's Avatar
probably some filament in the rear bulb that does double duty broke. Best to swap left and right bulbs to see if the fast blink changes to the other side, and swap individual bulbs to narrow it down to a specific one.
Old 04-08-2013, 09:06 PM
  #19
record10's Avatar
It would take all of ten minutes and a 10mm deep socket to pull the rear lamps and do a visual...that is what it took for me to fix the exact same problem....
Old 04-09-2013, 05:53 AM
  #20
bcgreen's Avatar
I will have to investigate how to access that area. Is the access panel covered in carpeting?
Quick Reply: Lt turn signal blinking twice as fast as normal
