A new Twist on an old idea- TT dead Pedal install
<center><img src="http://pictureposter.audiworld.com/6174/img_2788_large.jpg"></center><p>Glued the tong back on- had to use the tab from my stock A3 pedal to fit right
and the mess is from testing 4 different glues to see which would stick - front side is perfect, so who cares what the back looks like.
Verdict- Lock Tight- superglue. tight as hell will not come off- - and the fit in the car is super tight as well. no movement at all
<img src="http://pictureposter.audiworld.com/6174/img_2789_large.jpg">
Your sig says RS4 dead pedal. Is the TT one better?
And you have TT pedals instead of the gli pedals i've seen people install? Or are they one in the same?
Did you try installing the TT dead pedal without the clip?
Where did you get the TT dead pedal?
.. Rs4 Pedal did not match just right..
.. Yes TT one fits and matches better.
.. TT and GLI peds are the same ( Gas and break)
.. Did not want to try with out the clip when i did the RS4 one with out the clip it moved around.
.. ECS- $79.00
More pics
<img src="http://pictureposter.audiworld.com/6174/img_0099_large.jpg">
<img src="http://pictureposter.audiworld.com/6174/img_0100_large.jpg">
<img src="http://pictureposter.audiworld.com/6174/pedals01.jpg">
.. ECS- $79.00
More pics
<center><img src="http://www.ecstuning.com/stage/images/dis/6177/600/6177.jpg"></center><p>which includes the dead pedal. It doesn't have the two groupings of rubber strips, which is the design I prefer. But you said $55... I see it listed for $79.<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi/?html=learnmore.html&productID=7408">ECS Tuning - A3 dead pedal</a></li></ul>
