oil filter housing drain
ECS sells one for 50 bones, are there any alternatives out there? Do you even need a spout? It looks as though you could drain it without one if you needed... ?
just do it normally once, and see if it makes enough of a mess that you'd want to spend $50 and handle a section of dirty oily tubing every oil change, instead. (and store a length of dirty oily tubing somewhere, between oil changes)
and you don't drain all your oil from there, just what's in the filter housing, so it's really not a big deal.
it doesn't make a mess at all on my car, it's a very clean process. i like it as it is
yeah, I know the only drainage is oil from the housing, but the reason I ask is because I did drain it without one -- and it was a mess
Luckily the auto parts store was kind enough to provide some cardboard that kept the concrete clean.
I may have made a bigger mess by trying to prevent making a mess. Being too careful may have lead to carelessness.
i didn't know that any tubing was necessary... i thought it was just a spout...?
<center><img src="http://www.samstagsales.com/images/vw_matra_t40057.jpg"></center><p>
<img src="http://www.ecstuning.com/stage/images/dis/7312/600/7312.jpg">
... the valve looks like a tire valve stem. It seems like thered be a very cheap and easy way to achieve the function of these drains without much effort.
i would, however, be pretty hesitant to go pokin around *****-nilly under there
