P2435 error code
P2435 error code
P2432 Code would seem to be Secondary Air Injection System (via Google)?
but a search here finds no results for A3 and P2432
If it is this: Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1 - Short to Ground
Where do I look to check the wiring?
I found the diagram, still need to locate #13 in the vehicle:https://parts.audiusa.com/showAssemb...sembly=6235094
2010 A3 / 2.0 TFSI
2010 A3 / 2.0 TFSI
sensor location
Thinking I have found the sensor, under the air cleaner housing/box. I shall try cleaning the connector but may need to remove the box above it.
Need to find instructions to do so and hopefully connector cleaning is all that is needed to remove the code.
Visti
Canadian Discussion
15
05-06-2024 12:47 PM
dudleydorighta4
02-08-2005 10:42 AM
