Powerflex bushing installed...
Cost, $27 + shipping. <a href="https://secure17.nexternal.com/shared/StoreFront/default.asp?CS=powerflex&BusType=BtoC&Count1=10114 6876&Count2=18287301">Link to website</a>
Look for VW | Golf MK5 | 5 - Lower Engine Mount Front PFR85-505
Parts laid out. Need to separate black arm from mount. Twist and turn to pull off.
<img src="http://i76.photobucket.com/albums/j12/krazyboi98/DSC00863.jpg">
Separated. Need to break off green plastic holding metal cylinder. I started off w/ a small hole drill bit to remove center rubber. Then used a hacksaw and made two cuts about 1/2-inch apart. Used a chisel and hammer and carefully broke the plastic. The whole thing will fall out.
<img src="http://i76.photobucket.com/albums/j12/krazyboi98/DSC00864.jpg">
<img src="http://i76.photobucket.com/albums/j12/krazyboi98/DSC00865.jpg">
Install bushing. Put both polyurethane parts in first. Then use silicone spray in the center and hammer in metal part w/ rubber mallet.
<img src="http://i76.photobucket.com/albums/j12/krazyboi98/DSC00866.jpg">
Reinstall mount. Should use new bolts. Can be found on <a href="www.worldimpex.com">World Impex</a>. Bolt info: N 104 548 01 and N 102 048 04
aluminumpork
09-08-2008 05:34 AM
