Replacement Panel Filters - Do they give results? .....
Guest
Posts: n/a
Guys, I've had poor feedback in the performace forum. Have you got any comments about whether replacement panel filters actually give extra performance?
Thanks for any help.
Regards,
Alan
'99.5 A3 1.8T MS Silver
Guest
Posts: n/a
I am sure they do but not as much as some would like / believe and on their own not much.
I seem to remember that AmD ( Oxford ) reckon that when chipped you are looking at 3-4 bhp.Their site (auto-amd.com )gives graphs etc from their rolling road.Take a look .I can recommend their services,I am very fussy and I have used them for about eight years.
Guest
Posts: n/a
Thanks Chris. Yeah, you hear about so many people fitting these filters to their cars, like its just the next step in mod'ing a car. And I just thought - well do they work?
I have visited AMD's site before. So you recommend them? I've been looking into chipping etc., and in the UK it basically boils down to either Superchips, AMD or GTi Engineering. Any experiences with any of those?
Do AMD socket the chips?
Cheers,
Alan
Cheers,
Alan
Guest
Posts: n/a
Hi
Very little difference is gained by using a panel filter on the 1.8T engine. In terms of actual power, I guess maybe 3-5% extra, in terms of road performance it is akin to driving with the air conditionition conpressor on or off - I can barely notice the difference.
I have not used the filter on my own car, but we experimented in a collegues A4 - the big difference is that you buy the filter once and then never replace it, certainly in the case of the K&N filter. It needs to be serviced every 50000 miles or so!
Better buy a chip and get 30+ bhp from the info I have read!
David R
David R
Guest
Posts: n/a
I'm not sure about the socket.
I am a very satisfied customer they look after my 1985 80 Sport .
I am hoping to get the A3 seen to once i have put a couple of thousand miles on it
The A4 has done 5 thousand miles and it will easily take a bit more power but as it has the 180 bhp engine i suspect it will only get to about 200bhp The drive by wire engines are also much more expensive to modify
I particularly like the before and after graphs so that you can see exactly what has been achieved
It is also programmed to the actual vehicle rather than an average best of some other suppliers. I do believe that some Superchips dealers now have modems and can hook up to the master computer at the headquarters.
Oxford is a long way for you ----but you would get a fun drive home !
Guest
Posts: n/a
Ah, Oxford is not so bad.
It's Birmingham & M6 that's the pain of motorway travel in England. I love the M40 though, it's a great motorway.
It would be a fun drive back with 195bhp!
I have read an old Audi Driver article about an AMD A3, and in comparison with the Superchips TT180 chipped (again Audi Driver), the superchips had the better mid-range performance. So...I don't know which I go for actually.
Alan
Alan
Guest
Posts: n/a
Thanks David. I figured they wouldn't make much difference in the standard car. It does make sense that a filter & chip combination would produce the best results, as I guess when they do the chip re-map, it would be done to take into account the extra air coming in through the new filter. (?)
Cheers,
Alan
Cheers,
Alan
Guest
Posts: n/a
Hi,
I was a bit sceptical at first but I reckoned the replacement had to be better than "the piece of dry paper" manufacurers put in the car.
I can't comment on the replacement air-filter effects on 150bhp car as my A3 was modified new (190bhp). After about 5000km I put in K&N panel and here is what I noticed, in order of significance:
- better acceleration or rather the pulling power at lower (very low) rpm's, also engine breathes better through rpm's, before then I wondered where my 190bhp was, I think it even drives at lower rpm's now;
- about 10-12% better fuel economy, some of which may be attributed to engine loosening up;
- slightly more power, don't know in bhp as I still have take it for a dyno, but perhaps 2-3bhp.
I've had the panel filter on all my cars before, not all of which were fast and I definitely recommend it. It's a cheap way of improving performance and letting your car's engine enjoy more air supply to achieve its peak output.
IJ
99A31.8T
IJ
99A31.8T
