Revo Technik introduces our performance programming for the A3 2.0T FSI
#21
My only comment was on reading the dyno, not argueing any of the actual numbers.
However again this is something else people like to ignore. All of the eurocode graphs are on 91 octane. The link posted for the A4 over on vwvortex/fourtitude was on 93 octane. At 5500 rpm that car is showing about 25+hp to the wheels. 93 octane programming in the same car would probably put them dead even.
So no one is not neccessarily making more then the other.
YOU HAVE TO LOOK AT EVERYTHING!!!!
#22
93 is good for 2-3 hp over 91 stock just like 93 is good for 4-5 hp over 91 chipped + what Nogaro said. APR is making more than just 5+19 and the range HP looks just as good if not better.
#24
Just because they're both a Dyno Jet doesn't necessarily mean they're going to result in the same numbers for the same car type. I've seen variences of up to 10 horsepower for the same car between two different Dyno Jet dynos. Add the octane consideration and the numbers are theoretically very close.
#28
The numbers you are using are at different rpm points.. So they are not valid to compare. Your 210 and 176hp numbers you pointed out are at different RPMs.. If you compare the performacne the the same rpm point a the 176 and the stock at the same point as the 210 you will see the gains are NOT what you are saying they are.
Spoonie G
Audi A3 / S3 / RS 3 MKII
25
11-22-2014 09:25 PM
Mr.FRU-T-Pants
Audi Original "S" Cars
03-24-2008 07:18 AM
George@Revo Technik
A4 (B7 Platform) Discussion
20
12-23-2005 11:30 AM
2.8man
09-15-2002 12:25 AM
Cerveza
08-22-2001 10:10 AM
