Rns -E Voice Commands Problem
Hello. I recently bought Audi A3 '12 with Rns -E navigation plus system.
I have this problem. When I press the speech button in my steering wheel the system understands only the CALL command. As I see in my manual it should understand and other commands like HELP,RADIO etc. But mine works only with CALL.
My phone works perfect with bluetooth, and I have 0220 version in RNS.
Can anyone help me please?
I cannot do another test as the car got sold yesterday.
Probably you are right. If I activate the voice and don't say anything after some seconds it turns off. It understands only the phone commands.
hi, have 2009 a3 with rns-e and mfsw with voice and factory bt . can not get sds to work with nav or any execpt phone.
regards Phil
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 S HW: 8P0 035 192 S
Component: RNS-E HIGH EU H77 0650
Revision: 04S Serial number: AUZBZ7H4115954
Coding: 0209757
Shop #: WSC 00067 210 75633
2 Faults Found:
02261 - Data Medium
014 - Defective - Intermittent
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
regards Phil
Coding: 0209757
2 Faults Found:
02261 - Data Medium
HI, I HAVE rns-e plus and high line MFS and OEM BT ,. I want to enable full SDS .I have copied the 660 software to a cd .But i already have the 650 SW and i can see the SDS file on the Map DVD, (IT LOOKS THE SAME AS THE 660 SW) My concern is if I update with the 660 SW CD Will my Maps DVD with the 650 SW still work.
Also ,where is best place to pick up the Mic wires ?
Many thanks Phil
Originally Posted by Flakmunky ![](http://www.vwaudiforum.co.uk/forum/images/blackpost/buttons/viewpost-right.png)
Taken from my post over at Navplus.us
Info for others coming along later...![](http://www.navplus.us/forums/images/smilies/eusa_eh.gif)
All of this information comes from various threads on the navplus.us forum, however 'SDS' is too short a search term which makes it very hard to find the information so I thought a post with the full term in the title might make it easier for other noobs like me in future...![](http://www.navplus.us/forums/images/smilies/eusa_doh.gif)
Enabling the Speech Dialogue System (SDS)
I have just got SDS working in my A4. I downloaded the update CD (from here) burnt it to a CD-R (ISO-9660) and finalised the disc. The update took some time and appeared to have hung but it eventually went on and when it finished I had the SDS menu options.
I then recoded the Bluetooth module (from 1xxxx to 1xx0x) and after that pressing the PTT gave me a beep, then after 10 seconds or so the woman would give a list of commands, so I knew it was all working I just needed to rewire the microphone.
I had a couple of spare repair wires (000-979-009) which I put in to the following positions:
Quote:
Originally Posted by Dave.G6HNI![](http://www.navplus.us/forums/images/buttons/viewpost.gif)
MIC +ve ---> RNS-E MIC IN +ve ---> C7
MIC -ve ---> RNS-E MIC IN -ve ---> C1
And then used Scotchbloks to tap in to the Microphone wires.
Anyway, after I had the mic wired in, everything worked fine and as it should. In fact the microphone quality seems to have improved slightly but maybe that is down to too many beers after the install?!
Many, many thanks to all the kind people who post to this forum as they have helped me to install options which would have cost close to £3000 from Audi for approx. £650.
Regards,
fM![](http://www.navplus.us/forums/images/smilies/icon_biggrin.gif)
NOTES:
I couldn't recode the BT immediately (because my laptop needed rebuilding) and after flashing the SDS firmware I got some strange behaviour which disapeared when the BT was coded properly.
Basically until the BT was coded the RNS-E started complaining that the navigation disc was incompatible. Resetting the unit (hold Radio + Setup for ~6 seconds) and removing the disc showed the map, but as soon as I tried to set a destination it would hang.
Other people who hadn't recoded the Bluetooth module stated that the DIS displayed Speak and then immediatley afterwards Phone. Perhaps they didn't try using navigation?
Anyway, the brown trouser moment lasted until I coded the BT unit, whereupon all of the problems disappeared. To check if everything is working prior to pulling the unit and rewiring the mic, pressing the PTT should give a beep, then after 10 seconds or so the woman will say "Pardon?" and then after another 10 seconds or so a list of possible commands.
My experience suggests that if you don't like SDS you will have to 'downgrade' to the non SDS firmware and then recode your BT back as the two cannot co-exist, even if the mic is disconnected from the RNS-E.
Many thanks Phil
![](http://www.vwaudiforum.co.uk/forum/images/blackpost/misc/quote_icon.png)
Regards,
fM
NOTES:
SimianSpeedster
TT (Mk3) Discussion
04-17-2016 02:59 PM
