S3 Door Panel
I just did this 2 weeks ago - this is for
an A3 Turbo but i guess its the same
Remove 2 clearly visible screws from each
side of the panel
NOw, with a sharp instrument, gently lodge
out the plastic cover from the inside of the
door panel handle. It should simply fall out.
Remove the 3 screws.
You should now be able to lift up the entire
door panel - no force or jerking is required.
cheerio
side of the panel
cheerio
yup...sure can do,.....right the door is held on with 3 screws, one on the end with the latch, the other at the opposite end, then a screw underneath the handle( plastic insert which you can pull of),...its a tricky job needed two of us as you cant completely take the the panel off and rest it while you change the speaker, you'll need a speaker adaptor you can get this from incar-discount.co.uk speaker size is 13 cm.....i got some infinity ....wow sound ace...cya
quattro.pilot
05-15-2003 01:03 PM
Simon - UK
09-22-2000 06:27 PM
