Slight Jerk, Hesitation when you first press throttle
Hi guys,
I'm hoping you can shine some light on this, it's driving me mad!
Car Details: 2007, 1.6 Petrol Audi A3 (8P). 88K miles on the clock
Full Service: November 2019. All filters and oil changed and spark plugs
I have an issue where when I put my foot on the throttle, if I'm changing gear, or if I've been slowing down and put it back on to the resume, there is a slight hesitation and jerk. The rev needle rocks slightly and the car jerks. The car runs absolutely fine once the throttle is down and there is no jerking at all. Smooth as you like. It's just that initial putting your foot on the throttle.
At first I thought it might be to do with the fuel injectors, so cheapest option was to throw a bottle on Redex in a full tank. After I used that I then used Wynns Xtreme Cleaner on another full tank. No change
I then thought it might be something to do with the throttle body or air intake pipe. I took the air intake pipe off, gave it a clean (couldn't see any holes in the pipe). There isn't a maf sensor running from my air filter/pipe to the throttle body. I then run some Throttle body and air intake stuff through it. No change
OBD Reader - I plugged my scanner in to see if there were any error codes, but nothing. At Idle the Vacuum was at 20ish, which I believe is normal? (Revs were around 750. Throttle 1.5, Coolant 51c)
Reset ECU - Unplugged battery for 10 minutes, and then plugged back in, no change
Oil Level - I thought it could be a case that the garage had put in too much oil, but the level is OK
Vacuum Leak - I can't hear any hissing or air escaping anywhere. I've tried spraying a bit of water on some of the pipes, but couldn't hear any change in the engine to indicate a leak.
Perhaps I should try a smoke test?
Video of engine running at Idle - https://photos.google.com/share/AF1Q...UyR1VJYVQyUzl3
Does anyone have any ideas what else it could be?
Hi guys,
Devius
12
03-19-2007 01:45 PM
WD
03-03-2003 02:40 PM
Silvr1.8T
12-16-2001 05:04 PM
evilandy
05-25-2001 03:48 AM
NYLawyer
05-08-2000 09:23 AM
