Sway Bars?
crew219 is right. H&R!
go with the solid bar.
I have the premium/base suspension which handled like a golf cart. My first mod was a rear sway bar. Handling improved to car-like. I could now take S turns with a lot more confidence. It is still one of my fav mods. No drawbacks what-so-ever.
H&R rear sway.
H&R rear sway.
Re: What are the advantages/disadvantages of both?
weight is about the only difference you can get the same strength from a hollow bar than a solid but the diameter of the hollow bar will be bigger, but lighter than the solid.
I've heard that only a rear sway bar is really needed to get rid of understeer...
... Is that assuming you already have the sport suspension (in which case I assume it comes with a front sway bar)?
