Their mistake is your gain, TT "R" Front Brakes...
Audiworld Basic Sponsor
It appears that someone doing labeling made a mistake on these TTRS front calipers, instead of the proper "RS" logo only an "R" was printed on center of the caliper (conversely an opposing story is the original designation for the TTRS was supposed to be the TTR, though that would have possibly caused issues with Honda's Type R moniker, so these calipers are from the original planning phase). Regardless of how the calipers came to be the setup was prepared to be installed and the assembly was pulled due to the improper labeling. This means it is now available complete for anyone looking for a unique set of very serious all genuine OE big brakes at a special price:
4 Piston Monoblock "R" Caliper and 370mm Rotor
![](http://www.europrice.us/Temp/ttrbrakesa.jpg)
Massive 370x32mm Rotor
![](http://www.europrice.us/Temp/ttrbrakesb.jpg)
Assembly Mounted to Bearing Carrier - Brakes would be dismounted from bearing carrier
![](http://www.europrice.us/Temp/ttrbrakesc.jpg)
PRICING:
This system is bolt on for your TT Mk2 or A3 and includes all needed components for a bolt-on fitment. Calipers, rotors, pads, brackets, wear sensor, brake lines and splash guards. Will require 18" or larger wheels for fitment.
SHIPPING and DELIVERY:
Package is available now with direct delivery to your location. Delivery 7-10 business days directly to your location. Tracking number provided when your order departs.
HOW TO PURCHASE:
Europrice accepts Paypal and credit cards directly for quick and easy service. Please email if interested or would like to make a purchase: contact@europrice.us.
Thank you for your time,
PRICING:
- TT "R" Front Brake Package - $2606.89 each (Retail - $3863.77) Save - $1256.88!
HOW TO PURCHASE:
It very well could, 18" wheels are required, however having enough clearance on the backside of the spokes should be fine as the TTRS wheels are a 52 offset, meaning the spokes will be approximately 52mm outwards, you have a higher offset so should be fine with backspace clearance. There are 18" winter wheels for the TTRS which fit the system, so you should be good to go.
Cheers,
Cheers,
Alex@Europrice.us
TT (Mk2) Discussion
09-30-2009 02:07 PM
2low4snow
05-19-2006 06:47 AM
HACK THS
14
11-25-2001 06:28 AM
