Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Tire Pressure, My P6's cupping in the center, current 35F34R, dealer says
Old 12-05-2006, 04:52 PM
azoceanblue's Avatar
Default Tire Pressure, My P6's cupping in the center, current 35F34R, dealer says
that they are under-inflated. Oem specs are 35F32R. TIA
Old 12-05-2006, 05:56 PM
racer-genx's Avatar
double check the label, I think it supposed to be 39F35R
Old 12-05-2006, 06:41 PM
When you have a full load . . . .F39R35 is correct
Old 12-05-2006, 07:10 PM
Default Is it safe to run higher than oem recommended tire pressure? Excerpt from Tire Rack . .
"A tire's "maximum inflation pressure" may be different that the assigned tire pressure used to rate the tire's "maximum load". For example, while a P-metric sized standard load tire's maximum load is rated at 35 psi, many P-metric sized standard load performance and touring tires are designed to contain up to 44 psi (and are branded on their sidewalls accordingly). This additional range of inflation pressure (in this case, between 36 and 44 psi) has been provided to accommodate any unique handling, high speed and/or rolling resistance requirements determined by the tire and vehicle manufacturers. These unique tire pressures will be identified on the vehicle placard in the vehicle's owner's manual."
Max rating from tire is 51psi, I am trying to elimate the excess tire noise and cupping (located at the center of the tread). Going to try higher pressures, monitoring noise as well as performance. I will keep you posted.
Old 12-05-2006, 08:53 PM
MisterJJ's Avatar
Default I always run 2-4 higher than the sticker.
When I ran the recommended pressures I always got premature wear on the outside edges.
I have put 2-4 PSI more pressure for many years with many different cars and I always get even wear. To determine my set pressure I look at the bulge in the sidewall and set it to look "just right". Not too much and not too little. If, while standing, you have to look hard to see the bulge, it's too much air and if it's got an easily noticeable bulge, it's too little. Hard to describe further but after checking pressures for many years I've gotten a good feel for what looks right. Later, I'll check the wear pattern and adjust a little as needed. I'm running +3 PSI on my Pzero Rosso tires and have even wear so far.
Of course there are temperature considerations. I'm in Southern California so I don't have to worry about extreme temperature fluctuations.
Tirerack has good information about this, as usual:<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&amp;url=%2Ftires-techpage-1%2F147.shtml">http://www.tirerack.com/tires-techpage-1/147.shtml</a></li></ul>
Old 12-06-2006, 03:20 AM
Re: I always run 2-4 higher than the sticker - Thanks I'm trying +3 today )
Old 12-06-2006, 05:13 AM
Buddah's Avatar
my P6's cupped, loud as crap
Old 12-06-2006, 08:13 AM
Junior Member
dan-phx's Avatar
My P6's... 10k mi... woka, woka, woka. Sounds like Pac Man.
Old 12-06-2006, 01:05 PM
New Member
Soner-O's Avatar
Default 16000 miles on P6 and they are loud as hell. very embarrasing when you have...
passengers... i am considering to get either BF Goodrich g-force Sport or General Excalim UHPs.
Old 12-06-2006, 04:14 PM
New Member
WISVW's Avatar
Default All my VW products have cupped their tires
I've quit rotating them period and have had better luck with noise
Quick Reply: Tire Pressure, My P6's cupping in the center, current 35F34R, dealer says
