What is the "Bi" in Bi-Xenon?
The answer is probably as simple as the name suggests, but if I understand correctly, there is a form of Xenon that has a blinder that covers the upper half of the bulb which creates the low beam. When brights are selected, the blinder is lifted, thus high beams. Do bi-xenons work the same way, one bulb for low and brights and the second bulb is running lights or something, or is one bulb low and the other bulb brights?
I believe you're right. The interior light is DRL. And the xenons are shared.
<img src="http://i13.photobucket.com/albums/a279/iMryanmac/trip%20to%20HV/IMG_0080.jpg">
Flapped Xenon low beam and halogen highbeam with another plain bulb for DRL (daytime running lights?)? (3 bulb + Turn signal setup as opposed to current 2 bulb + Turn signal setup?)
What's the bulb on the far left of that set, Ryan? Signal indicator?
Theun
15
03-18-2006 03:18 PM
CMC
10-12-2001 06:53 PM
