What exactly are the changes to the 2.0T? Were they done primarily to address the fuel system..
issues? Output is the same though, correct? Is it the same engine with only minor changes?
Etc...Its very very different<ul><li><a href="http://forums.vwvortex.com/zerothread?id=3784960">http://forums.vwvortex.com/zerothread?id=3784960</a</li></ul>
same on the transverse engines. 11hp and 58 ft/lbs isn't THAT big of a change on a turbo car.
That's actually a pretty substantial boost for a factory engine. If it were aftermarket, sure, that's mild tuning. But for factory that's pretty substantial.
Also, seeing that much increase in torque with so little change in hp gives the impression of changes to the engine's stroke characteristics or to the turbine/impeller design on the turbo.
1.8T when it went from 150 to 180 hp in torque? Audi gives decent increases.
ayap
2.0T FSI Discussion
01-20-2014 07:08 AM
MonzaA5
02-02-2011 07:00 PM
AndrewM (azdaspeed3)
05-04-2000 05:18 AM
