What is tallest Tire size that will fit without rubbing
Greetings
I am search of the tallest tire size I can run on the A3q without rubbing (turning or bumping the top of the fenders over bumps).
These will be dedicated winter wheels and will be narrower. I want more clearance for snow and gravel roads. I am not concerned about affects on the speedo. I do want decent HWY drivability. I am likely going to use 17x7.5" rims and would prefer a 205 or 215 width.
I did some research and the stock tire options for the A3q are:
225/40-18 (Total diameter: 135.72mm)
225/45-17 (Total diameter: 144.43mm and 6% taller than 225/40-18)
205/55-16 (Total diameter: 153.38mm) and 13% taller than 225/40-18)
Has anyone ever gone to anything taller like these:
205/55-17 (Total diameter: 155.93mm and 15% taller than 225/40-18)
215/55-17 (Total diameter: 161.43mm and 19% taller than 225/40-18)
Thanks in advance
Mike
Thanks in advance
Mike
Hi Mike - I'm also searching for snow tires, and looking for some used that will fit our 2006 A3 2wd. Did you figure out what other 17" tires would fit than the stock 225/45 17?
Thanks!
Thanks!
GregC6A6
06-24-2008 09:47 AM
Question: If I want to get 225 size tires for my OEM 15 inch wheels, what does the ration need to be
poopeter-el sigthief
08-01-2002 11:51 AM
simply J
04-04-2002 12:49 PM
S4elvis
09-26-2000 09:13 AM
