Active Lane Assist Activation via VCSD
#11
I don't know, I don't use RossTech VCDS, I use OBDeleven. If you get active lane camera installed you will definitely need to get it aligned and likely calibrated by the dealer. I remember calibration being a question when I got the windshield on my A3 replaced but I didn't need it. But I don't think a new ActiveLane camera added to the car in your case will work instantly with getting flashed by the dealer.
#12
I upgraded my 2017 audi a3 8V FL with a A5 3Q0907654H camera
I coded the camera without errors, I performed the calibration which ended correctly.
I have a problem with the correct coding and adaptation of the drivers
I did the same as in the Audi A4, but not everything matches the A3, I have Line Assist in the menu, but the system does not work
Lines from lane assist do not appear on the display, I also do not have any icon from lane assist.
What I have bad or not coded on my A3 that the system does not want to work.
Could it be the camera's fault?
Coding and adaptation
UPDATE:
Security codes:
A5- 20103
ALL Coding:
A5 - Frt Sens. Drv. Assist
HC>Active Byte 16>Bit 7
EFP>Active Byte 12>Bit 3
17 - Dash Board EDIT:
Lane Assistant>Active Byte 4>Bit 6
Lane Change Assistant>Active Byte 5>Bit 3 - This should only be on if you have Audi Side Assist (blind spot monitor).
09 - Central Electrics
Heading Control Config>heading_control Byte 35>Bit 0
////// I can't do this on an Audi A3 8V
44 - Steering Assistance
Heading Control Assistant>Active Byte 2>Bit 7
ALL ADAPTATIONS:
5F - Information Electronics
Car_Function_Adaptations_Gen2>menu_display_Lane_De parture_Warning = Set Value to Activated
Car_Function_Adaptations_Gen2>menu_display_Lane_De parture_Warning_over_threshold_high = Set Value to Activated
Car_Function_List_BAP_Gen2>LDW_HCA_0x19> Set Value to Activated
Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus> Set Value to Terminal 15
BAP Personalization = Set Value to Not Activated
Personalization of lane dept. warning Cl. 15 on = Set value to Last Setting
System mode, lane depart. warn, = Set Value to Selection via menu
Switch-on condition, lane depart. warn. = Set value to On (I had to toggle this as this is the final step that I believe mimics pressing the button to actually activate it. You know it was successful when the Lane markings show up in the VC)
You can tweak the vibration intensity, warning time, and steering effort in these A5 adaptations:
UPDATE
/////I can't do this on an Audi A3 8V
Directional stabilization assist driver inact deactiv threshold (3 options)
Directional stab. assist.: intensity: steering wheel vibration (3 options)
Directional stab. assist.: intensity: power steering support (3 options)
UPDATE:
Security codes:
A5- 20103
ALL Coding:
ALL ADAPTATIONS:
UPDATE
achilleas101
Southeast Discussion
10
06-25-2008 05:39 PM
G18
09-24-2003 11:07 AM
Angry Alex
02-27-2002 07:53 PM
