Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
Old 08-05-2016, 11:59 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A3 Engine Guides
Print Wikipost
Audi A3 2.0T Oil Change
Old 01-02-2015, 02:20 PM
  #21
Indigo4298's Avatar
Per my Audi salesman, the plastic oil pan drain plug is a one time use. Once it's taken out, you'll have to purchase and install a new one. Audi only uses oil extractors now on their vehicles.
Old 01-05-2015, 12:18 PM
  #22
Spoonie G's Avatar
Originally Posted by lordjop
This is the one I have:
Multi-Fluid Extractor - Griot's Garage
Going to pick one up myself! Great price! I plan on changing the oil every 5000 miles alternating between myself and the dealership doing it under Audi Care. Thanks for the post!
It will be the easiest oil change ever. The oil filter is right next to the drain plug no need to go under the car. My BMW had the same setup and I was able to change the oil with dress clothes on.
Old 03-31-2020, 09:48 AM
  #23
ThisIsFRSH's Avatar
Good to know!
Old 04-18-2020, 05:11 PM
  #24
MP4.2+6.0's Avatar
Visiting from Q3 (gen 2 for me) forum.
Going back to early in thread, yes the drain plug is plastic if you want to do it that way. Either a typical mid size Philips or flat blade screwdriver fits in it. ECS (or dealer) sells them for a few bucks. On new Q3, the oil spec is now OW-20 508.
As stated, dealers are typically siphoning out dipstick hole. They were on my 2013 Q5 2.0T too, even though it has a steel pan and conventional drain. On my S8 4.0T, the oil filter is on the bottom, so it forces them to pull belly pan. More than anything, it is that position of the oil filter that determines whether dealer does it from above or below.
audiinnj
A4 (B8 Platform) Discussion
9
12-05-2018 04:31 AM
kevin880
A6 (C7 Platform) Discussion
09-15-2015 06:17 AM
Christina Wong
09-11-2015 09:43 PM
thehedge
09-05-2015 09:02 AM
jjyerro
09-01-2015 10:01 AM
Quick Reply: Audi A3 2.0T Oil Change
