DIY Virtual Cockpit firmware update
#11
I first update to 0150 then the bug appears.
After that, I found the 0162 version and follow your tuto again, and bug still present.
I will check if a new version will be released soon and update again.
If the bug still's here, I will try a downgrade to 0069.
If just the milage to reprogram by Audi it will cost less money (lol) than changing the whole unit as they planned to
#12
I decided to update my old 0045 firmware with much newer 0150 that I've found on mibsolution.one
And as usual, I had my camera with me to make a tutorial for other Audi owners.
0. Warnings and info
1. Ignition on, press trip reset buttons [0.0] five times, and keep it pressed on the fifth.
This will open hidden screen on the instrument cluster where you can check which firmware you are currently running. It will be in the SW: line. In my case it was 0045.
You can also check this with OBDeleven or VCDS. Up to you.
2. Find and download desired firmware update for your VC on mibsolution.one (user and password: guest).
In my case AU_C1_AU37X_0150_0742_prod; P/N: 8W6906961R designed for KI_FPK_AU37X device.
3. Prepare SD card. I've used 16GB SD, formatted with FAT32 file system, 4096b allocation size. Copy over the unzipped update files to the SD card.
You need to place the update files in the top directory of the SD card. In such way that the update folder and the metainfo2.txt file are in root directory of the card.
4. Prepare the vehicle:
5. Insert SD card with VC firmware update to SD1 port.
6. Enter hidden red menu, go to Update, select SD1 as the update source, start the update.
It will takie about 5-10 minutes. VC will go dark and indicators/warning lights will flash during the update. MMI System will reboot several times. Screen will go dark several times. That's normal. Do not interrupt the update.
7. Around 5-10 minutes later you will see update summary. Confirm it. On the next screen hit "Cancel". MMI unit will reboot one more time.
8. In module 5F you will see fault code B201A. Use https://mib-helper.com/im-so-xory/ to fix this. But if you leave it, it will not cause any harm. It will not limit the functionality in any way.
In several other modules you will see "Databus missing message" and "Lost communication" faults. This is normal since MMI and VC were unavailable for several minutes. You can clear those faults from all the modules.
9. Remove the SD card from MMI.
10. Enter hidden menu in VC to confirm that the instrument cluster is running newer firmware.
11. Enjoy!
Changes that I found:
Bugs from FW 0150:
- Do at your own risk!
- It was reported that downgrading firmware caused instrument cluster EEPROM damage.
- You will need and SD card. Don't use USB drive. Don't use microSD + adapter, only good old full size SD card.
- If you have keyless system (KESSY), best if you tape the keyfob to the steering column. Update will not start if the key is not there.
- Car battery needs to be in good condition or an external power supply needs to be connected as a safety measure.
- Fault code B201A will appear in module 0x5F (MMI main unit), but it's easy to fix it if you have OBDeleven, VCDS...
- Missing communication faults will be present in other modules. This can be cleared with OBDeleven, VCDS...
- Read all before starting. If something is unclear, don't update until you know what you are doing.
- tape the key next to the ignition coil,
- ignition ON,
- engine OFF,
- lights OFF,
- fans, heating, USB chargers, other electrical consumers OFF,
- SD cards and USB drives removed from media ports.
11. Enjoy!
- current tab memory works after ignition is switched off
- phone tab redesigned
- maintenance service message fix
- minor bug fixes and stability improvements
Bugs from FW 0150:
- Audi eTron range display icon is misplaced
I followed your youtube tuto, and impossible for me to update my VC.
I have an A3 MY2017 hardaware is 8V0920790A H16 and software is 0066
I took the same update file as your and the file is view in my MMI as "AU_C1_AU37X_0162_0861_prod_8W6906961H" but i don't have the line "KI_FPK_AU37X" into so impossible to update...
I noticed yours is 8V0920790 H13. Do you think that's why i can't update?
Thanks
#14
#17
#18
i fanally found my problem….MOST was off…I don’t know why but now is ON and I’ve done my update
#19
Hello Mr. Fix
You wrote that the speedometer of one user was reprogrammed by Audi without replacing the Virtual Cockpit?
Do you have more information about this update?
Which HW / SW of the Virtual Cockpit was VC before Audi did the update?
Did Audi first downgrade the version from 0162 to 0066 or simply install the original software (they programmed the original VC as if it was new) without restoring the original version first?
VenomSeb (05-29-2024)
