Exterior Window Trim Gap with Seal Above B-pillar
Is the gap between the exterior window trim and the seal above the B-pillar bigger for the rear door than the front door (if one looks up from below)?
I find the gap to be quite a bit bigger in the rear door than the gap of the front door. I am just wondering whether this is normal.
Could someone please post some close-up pictures of the gap between the exterior window trim and the seal above the B-pillar for the rear door (the pov needs to go from low to high, i.e. looks up from a low angle).
Thank you very much in advance.
Smokesignals
03-20-2015 07:46 AM
feakara1
10-03-2006 01:16 PM
