When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Made a stupid move and took my car through guided rail car wash
So, I didn't realize it was a guided rail car wash until after I had paid for it. All it said on the outside was that it was touchless. When I realized it wasn't and I was already pulled up, I saw a vehicle behind me and I felt somewhat pressured to just go through so I didn't hold up the line. Anyways, I went through and the first little bit I felt my front left tire rub up against the side and then it got adjusted and it was fine for the rest of the car wash. After leaving I looked and felt it all and it seemed to be fine, I went in to ask if it was indeed metal railing and they said it had a plastic covering over it, so that was a bit of a relief.
When I got home I took my hand and felt the inside of the front left tire (where it rubbed) and I felt this little crack, but it seems so odd. I thought it would have been more rubbed off than cracked if anything, but maybe this is just an anomaly with the rim and it's all fine? I put my phone in the inside of my tire and tried to get some pictures, here they are (I rotated the tire around a bit to get a few different angles):
What do you guys think? I'm never doing that again.. only by wand, I've learned my lesson.
I don't believe that is a safety concern and would be glad to see its on the inside where only you are aware it's there.
To me it looks more like damage to the wheel's finish coating.
Great lesson learned, I wouldn't have thought this would happen in a car wash and have warned my wife over and over about avoiding them, which she has, but now I can show her this.
That's exactly what it is. I took it and propped it up a bit in the sunlight so I could see it better and it looks completely fine, just a bit of ridge built up from the coating. I don't think this would have even happened from the car wash, I don't recall it hitting any of the rim there, just a bit of the tire. So it must have came from the factory like this.
Well, close call and lesson learned... only doing wand wash from now on. :-)
Just a comment on DIY drive-in (water wand) car washes:
A few years back in a car other than my Audi, I used one of those and while I was on high pressure wash, the brass (I guess it is brass) tip on the water wand (my term) came flying off and hit the car. It left a tiny chip that luckily I was able to hide and mostly rub out. It was a lesson learned. The spray tips are threaded on and this one had loosened up (I guess with all the vibration it gets) and at just the right time in its life came flying off under the high water pressure. Now I test all the tips by hand, making sure they are fully tight, before I pull the trigger. I keep a Leatherman tool with me in case I have to tighten one, but haven’t had to since that one sorta bad incident.
Anyone have any suggestions of products that help to lower curb rash... Specifically the face side? Found some foam looking stuff on Amazon that goes on the lip but I'm in the fence about it.
4 Pack Rimskins - Car Rim Protector (Silver) https://www.amazon.com/dp/B00JW3EWVE/ref=cm_sw_r_awd_crtPvb8ABJTVD
I ran my wife's van through one once and it ripped the back bumper off. The wash at first wouldn't pay to have it fixed saying their equipment doesn't do that. It was a fight but they eventually did. Never will I go through any automated car wash again.
I just bring a bucket, car suds, and some towels to the WAND.
And quarters but some take CC
And go late at night to avoid any hassle. The wand stalls are a ghost town after 9 pm. And no one will complain about you taking up time. They are always lit. I've gone as late as midnight sometimes
i use the minimum quarters to clean and fill the bucket as well as soak the car and lightly spray with final rinse setting. NEVER use high pressure on your paint or even wheels (if u got the 19s)
then i lather a micro fiber and clean in top to bottom. A final rinse does the trick.
dry up. flawless everytime
