Malfunction Code help
Hello,
I just got my VAG cable (2016 Audi S3), and I did the auto-scan option on the car. A fault code/malfunction came back and I had no idea where it came from. Can you guys help me figure out what this is?
1 Fault Found:
6669 - Optical Data Bus for Digital Sound System
U10CC 00 [008] - Intermittent Disruption
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 198
Mileage: 2538 km
Date: 2015.11.02
Time: 16:05:25
Thanks in advance!
-Sergio
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 198
Mileage: 2538 km
Date: 2015.11.02
Time: 16:05:25
Thanks in advance!
-Sergio
I apologize.
I didnt think the whole code was needed. Look below:
Code:
Saturday,12,December,2015,10:44:57:04737 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 15.7.2.0 (x64) Data version: 20151124 www.Ross-Tech.com VIN: WAUB1GFF4G1003477 License Plate: Mileage: 3938km-2446mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FF (5Q0) Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 52 55 5F 6C A9 VIN: WAUB1GFF4G1003477 Mileage: 3938km-2446miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 14-Susp. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 2B-Steer. Col. Lock -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 6C-Back-up Cam. -- Status: OK 0000 A9-Struct. Borne Sound -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CYFB) Labels: 06K-907-425-V1.clb Part No SW: 8V0 906 259 H HW: 06K 907 425 E Component: 2.0l R4 TFSI H13 0002 Revision: --H13--- Coding: 0A1D00122426000E3004 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_ECM20TFS0208V0906259H 001003 ROD: EV_ECM20TFS0208V0906259H_AU37.rod VCID: 45AFA5C7C4B3671618-8010 No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb Part No SW: 0D9 300 012 HW: 02E 927 770 AQ Component: DQ250-6A MQB H53 4903 Revision: 05853104 Serial number: TFK01504252316 Coding: 0014 Shop #: WSC 04742 780 00200 ASAM Dataset: EV_TCMDQ250021 001001 ROD: EV_TCMDQ250021_AU37.rod VCID: 538B8B9F3AE7C9A686-8006 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb Part No SW: 3Q0 907 379 K HW: 3Q0 907 379 F Component: ESC H42 0622 Revision: 00000000 Serial number: 61295000000130 Coding: 31FF6B9254200A6F017B030741CA698CD62A5080C08296B6024100D88208 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036 ROD: EV_Brake1UDSContiMK100IPB_AU37.rod VCID: 42A5BEDBD59D502E3D-8016 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb Part No SW: 5Q0 959 435 A HW: 5Q0 959 435 Component: VWKESSYMQB 021 0604 Revision: 00021000 Serial number: 0367629102 Coding: 030C0C Shop #: WSC 00000 000 00000 ASAM Dataset: EV_KessyHellaMQBAB 002011 ROD: EV_KessyHellaMQBAB_AU37.rod VCID: 3A55C63BBD4D18EE65-806E No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb Part No SW: 8V0 820 043 D HW: 8V0 820 043 D Component: AC Automat H13 0060 Revision: 20027000 Serial number: 00000000644168 Coding: 03000014010000000000000000001400 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_AirCondiFrontVaAU37X 008020 ROD: EV_AirCondiFrontVaAU37X.rod VCID: 334BEB1F9A27E9A6A6-8066 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: None Part No SW: 5Q0 937 085 AJ HW: 5Q0 937 085 AF Component: BCM MQBAB HNA H24 0173 Serial number: 01061513200234 Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_BCMMQB 015001 ROD: EV_BCMBOSCH_AU37.rod VCID: 012771D7901B8B3664-8054 Slave 1: Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB Component: WWS371 150506 042 0585 Serial number: 150513134434 Coding: 0A47F7 Slave 2: Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 23959128 Coding: 00006C Slave 3: Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA Component: E1 - LDS MQB H05 0032 Serial number: 28 02 2015 00000019 Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605 Component: Sirene, DWA 004 0311 Serial number: 00000000000032450416 Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A Component: J245 PS73.404 H03 0004 Serial number: 0000FST000AEQ5J00000 Coding: 101F00 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A Component: PARKHILFE 8K H03 0054 Revision: -------- Serial number: 39391512503486 Coding: 0030150011 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_EPHVA18AU3700000 002026 ROD: EV_EPHVA18AU3700000_AU37.rod VCID: 43ABBBDFCA87592636-8016 No fault code found. ------------------------------------------------------------------------------- Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb Part No SW: 8V0 907 376 E HW: 8V0 907 376 E Component: DAEMPFUNGS-SG H09 0072 Serial number: 120515009 ASAM Dataset: EV_AudiMagneRide 002003 ROD: EV_AudiMagneRide_AU37.rod VCID: 43ABBBDFCA87592636-8016 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 5Q0-959-655.clb Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J Component: AirbagVW20 009 0825 Serial number: 003GCR021CA/ Coding: 9DCCFCC0000000005000001AC24800000065 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_AirbaVW20SMEVW37X 002138 ROD: EV_AirbaVW20SMEVW37X_AU37.rod VCID: 47B3AFCFFEBF7506EA-8012 Seat belt tensioner; left: Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B Component: BeltPretRevFL H36 0350 Serial number: 34178311B13051570249 Coding: 333135 Seat belt tensioner; right: Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B Component: BeltPretRevFR H36 0350 Serial number: 34178312B13051570466 Coding: 333135 Seat occupant detection; front passenger side: Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B Component: BF-Gewichtss. H10 0046 Serial number: 6940000Y150001C49706 Coding: 303233 Crash sensor for side airbag; driver side: Subsystem 4 - Part No SW: ----------- HW: 480 002 504 15 Component: SideSensor_Df 001 0887 Serial number: 35700000000E2C1D031I Coding: 2D2D2D Crash sensor for side airbag; front passenger side: Subsystem 5 - Part No SW: ----------- HW: 480 002 504 15 Component: SideSensor_Pf 001 0887 Serial number: 3580000000078C1D031I Coding: 2D2D2D Crash sensor for side airbag; rear; driver side: Subsystem 6 - Part No SW: ----------- HW: 480 402 804 15 Component: SideSensor_Dr 001 6149 Serial number: 35100029D1A8787491CE Coding: 2D2D2D Crash sensor for side airbag; rear; passenger side: Subsystem 7 - Part No SW: ----------- HW: 480 400 405 15 Component: SideSensor_Pr 001 6149 Serial number: 3520002AB1A14CC2521/ Coding: 2D2D2D Crash sensor for front airbag; driver side: Subsystem 8 - Part No SW: ----------- HW: 480 402 502 15 Component: FrontSensor_D 001 6149 Serial number: 3550002C919DB8B3738O Coding: 2D2D2D Crash sensor for front airbag; front passenger side: Subsystem 9 - Part No SW: ----------- HW: 480 402 502 15 Component: FrontSensor_P 001 6149 Serial number: 3560002C919DB8B0922H Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb Part No SW: 8V0 953 521 FH HW: 5Q0 953 549 E Component: Lenks. Modul 003 0110 Revision: -------- Serial number: 11051504400567 Coding: A018 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_SMLSKLOMQB 017001 ROD: EV_SMLSKLOMQB_AU37.rod VCID: 052F65C78433A71658-8050 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb Part No SW: 8V0 920 972 B HW: 8V0 920 972 B Component: KOMBI H03 6420 Coding: 0BED181B3B88D7050201E8001800000000000000 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_DashBoardVDDMQBAB 009046 ROD: EV_DashBoardVDDMQBAB_AU37.rod VCID: 3D5FCD27AC632FD640-8068 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M Component: GW MQB High 212 2223 Revision: -------- Serial number: 11051510800004 Coding: 0101000830085A005B00022C980B00000001010000000000000000000000 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_GatewConti 013020 ROD: EV_GatewConti.rod VCID: 75CF1507D4D3B79648-8020 Alternator: Multifunction unit control module: Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C Component: E221 - MFL H02 0014 Serial number: 01 05 2015 E0001524 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels: 0CQ-907-554.clb Part No SW: 0CQ 907 554 D HW: 0CQ 525 130 Component: Haldex4Motion H52 7082 Serial number: HA1-00030.03.15 Coding: 0001 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_AllWheelContrHA1VW37X 002013 ROD: EV_AllWheelContrHA1VW37X_AU21.rod VCID: 46ADA2CBF9B56C0E11-8012 No fault code found. ------------------------------------------------------------------------------- Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A Component: ELV-MQBA H01 0120 Revision: 00000000 Serial number: 15000116614001 Coding: 5D00000000000000 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_ELVMarquMQB 004111 ROD: EV_ELVMarquMQB_AU37.rod VCID: 3449E8039F29EE9EBF-8060 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B Component: SWA Master H05 0080 Serial number: 0365953627 Coding: 030211 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_LaneChangAssis 001020 ROD: EV_LaneChangAssis_AU37.rod VCID: 3851DC3383410AFE93-806C Lane Change Assistant 2: No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B Component: TSG FS 020 0041 Serial number: 150415BDE04105 Coding: 005D1B204000048000000002 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003 ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod VCID: 43ABBBDFCA87592636-8016 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H Component: EPS_MQB_ZFLS 505 5061 Coding: 8102 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_SteerAssisMQB 012140 ROD: EV_SteerAssisMQB.rod VCID: 3753DF0F8E5F05869A-8062 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B Component: TSG BFS 020 0041 Serial number: 260415BDQ06546 Coding: 005D13204000048000000002 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003 ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod VCID: 42A5BEDBD59D502E3D-8016 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb Part No SW: 7P6 907 357 C HW: 7P6 907 357 B Component: AFS-ECU H01 0110 Revision: -------- Serial number: -------------- Coding: 0122000123200400 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001 ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod VCID: 3FA3B72FA66F3DC652-806A Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB Component: LED LeiMo li. H07 7560 Coding: E00100 Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB Component: LED LeiMo re. H07 7560 Coding: E00100 Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Component: LeiMo links H01 7050 Coding: E00100 Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Component: LeiMo rechts H01 7050 Coding: E00100 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: Redir Fail! Part No SW: 8V0 035 038 B HW: 8V0 035 038 B Component: MU-H-LNS-US H43 0394 Serial number: A302E0FB013006 Coding: 017301020000000021220002041A00102F000225010001047E Shop #: WSC 06385 790 00016 ASAM Dataset: EV_MUHig6C3HBAS 001040 ROD: EV_MUHig6C3HBAS_AU37.rod VCID: 334BEB1F9A27E9A6A6-8066 Engine Control Module 2: Subsystem 1 - Part No SW: V03 959 800 SS HW: ----------- Component: NAR 2015 --- 0035 Serial number: -------------------- Seat Adjustment Driver Side: Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C Component: DU High H49 0014 Serial number: AUZ8Z9FY2032XL Sound System: Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L Component: ControlUnit_H H81 0816 Serial number: C1000019031500030191 Door Electronics Rear Left: Subsystem 4 - Part No SW: V03 959 800 EG HW: ----------- Component: Gracenote --- 3006 Serial number: -------------------- 1 Fault Found: 6669 - Optical Data Bus for Digital Sound System U10CC 00 [008] - Intermittent Disruption Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 198 Mileage: 2538 km Date: 2015.11.02 Time: 16:05:25 ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J772) Labels: 5Q0-907-441.clb Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A Component: MQB RVC Mid H07 0140 Coding: 027300010201000300 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_2CamSysRearPASE 006016 ROD: EV_CamSysRearPANAAU914.rod VCID: 3041E4136B31D2BEDB-8064 No fault code found. ------------------------------------------------------------------------------- Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb Part No SW: 8V0 907 159 HW: 4H0 907 159 A Component: SAS-GEN 2 H06 0012 Serial number: 150422200555 ASAM Dataset: EV_SoundActuaGen2AU64X 003010 ROD: EV_SoundActuaGen2AU64X.rod VCID: 7DDF0D27ECE3EFD600-8028 No fault code found. End-------------------------(Elapsed Time: 04:01)--------------------------
So your fiber connection is having interim issues. Its what is used for the sound system.
I'd just let it ride till your next oil change or service. If you don't see or hear issues with the entertainment system, let it go till you're at the dealership next.
Bob 2KS4
10-18-2022 11:16 PM
