New Product - S3, RS3 Programmable CETE Exhaust Valve Controller...
Audiworld Basic Sponsor
A little extra flexibility and programmability has come to the already popular CETE exhaust valve controller...
![](https://s3.amazonaws.com/zcom-media/sites/a0iE000000Deia7IAB/media/wysiwyg/ceteexhaustbled.jpg)
![](https://s3.amazonaws.com/zcom-media/sites/a0iE000000Deia7IAB/media/wysiwyg/ceteexhaustblee.jpg)
Information:
With this exhaust valve control module you have the ability to better control your exhaust valves and program their behavior via a smartphone app. The controller allows you to program exactly how you would like the exhaust valves to behave in specific drive select modes. The exhaust valves will also automatically be set to the last drive select setting upon startup. The safety RPM for the valves opening can be set to the user specific setting. The factory control button that is double tapped to turn the module on and off completely can be programmed to be the ESP or Auto Start/Stop (if applicable). The full drive select system stays intact and functional, plus no added key fobs or controls are needed. Works with all models that have factory or aftermarket exhausts with valving that are utilizing the factory control systems.
Questions, Quotes:
If you have any questions or needs other than those posted above please don't hesitate to PM/email: contact@europrice.us
Cheers!
- Complete Control of Exhaust Valves with Factory Controls
- No Additional Key Fobs Required for Full Control
- Updated Intuitive and Simple to Use App - Bluetooth Connection to App makes for Easy Use
- Valves can be Opened and Closed via App
- Plug and Play - No Cutting/Splicing is Required
- User Programmable - Fully Open Valves or Speed Sensitive
- User Programmable - Fully Closed Valves until User Specific RPM
- Startup - Valves Revert to Last Setting Used on Shutdown
- Programmable ESP or SSA Double Tap - Turns Module On/Off Immediately
Information:
Questions, Quotes:
Cheers!
If you turn the module "OFF", does this mean the valves will operate in Factory mode (as if the module wasn't even installed)? I just want something that will either fully open all valves or Factory mode as I don't want to mess with any opening/closing of the valves other than the factory settings.
If you just want a simpler controller that does, closed valves (until 5k rpm) for comfort, standard factory behavior in auto and open all the time in dynamic the non programmable module will set you up:
https://europrice.us/controller-pack...-exhaust-valve
Cheers,
Thanks for the quick response.
I think I understand how this work now after your explanation. Basically, ESP double-tap turns the module ON/OFF. With the module turned ON (ESP double-tap), the valves are closed (until 5k rpm) for comfort, standard factory behavior in auto and open all the time in dynamic. With the module turned OFF (ESP double-tap), it behaves as if the controller isn't installed and the factory system is in control - thanks for the clarification!
But what if I want something that will open the valves all the time regardless of what mode I'm in, and then have the option to revert back to factory behavior? It appeared that the simpler controller will require me to run in dynamic mode in order to have the valves open at all times? Maybe there's a way to do what I want and I'm just not seeing it?
You could use the programmable module to keep the valves open all the time in every single mode if you want. You could set a profile for each drive select exhaust mode that has valves open at zero rpm to redline.
The programmable controller posted here allows you to program what the valves do for each drive select mode. Then when you want the system off completely you double tap the ESP.
Hopefully that would work for you.
Cheers,
Cheers,
Alex@Europrice.us
Q5/SQ5 MKII Discussion
31
09-22-2022 12:32 PM
Alex@Europrice.us
TT (Mk3) Discussion
02-19-2019 11:32 AM
Alex@Europrice.us
A6 (C8 Platform) Discussion
02-11-2019 09:09 AM
Alex@Europrice.us
Audi R8
09-12-2018 01:24 PM
