RS3 Homelink?
1 Post
https://duckduckgo.com/?q=Chamberlai...1Kv1TlF9LL.jpg
I ordered this model yesterday. Will advise after I get it if it works with both my garage door opener and my neighborhood security gate. My understanding is that there isn't space in the RS3 overhead console for both active lane assist camera/hardware and homelink hardware.
This has been somewhat of an issue for facelift 8V vehicles.
The latest I have found is that if you have the upgraded camera in the higher line trims of Audi Pre-sense (Prestige S3 and RS3) there is no room in the headliner for the Homelink transceiver. The lower trim variants of the 8V have it (Premium Plus S3). I learned this the hard way as I test drove a PP which had it and assumed my Prestige trim would to as well. My car does not have it and the dealer did not help in getting it installed for me (port installed only).
I would imagine it is on your RS3 order sheet that needs to be checked.
Correct. It would be on the dealer's build sheet for the car (not Audi's website).
Just like with "Resonator Delete Sound Enhance" option. It is not listed anywhere with Audi on their site but when you order a car it is on the custom order build sheet as a port installed option.
My guess is Homelink would be on this sheet that you need to tick the box (~$359MSRP). If not, then they have not fixed the clearance issue.
I did read a thread here of someone who retrofitted the transceiver. I think it mentioned having the connector in the wiring harness and only the switch pack needing to be plugged in for operation.
My WHY EVO remote opener, referenced in post 4 above, arrived in the mail today. So far I've been unable to get it to learn from my 2 other remotes. Anyone tried one of these and been successful in programming it?
My WHY EVO remote opener, referenced in post 4 above, arrived in the mail today. So far I've been unable to get it to learn from my 2 other remotes. Anyone tried one of these and been successful in programming it? https://www.amazon.com/EVO-Universal...ge+door+remote
I was able to program a Liftmaster and 2 Genie doors with it fine.
Once it is programmed correctly, you can get it to open the garage door with a simple short click of the button on WHY EVO. You don't need to hold down the button like on homelink.
Are your garage doors the rolling code type? If so, you still need to pair the WHY EVO with the garage door via the garage motor learn button.
https://www.youtube.com/watch?v=1SMY4izO204
