Last edit by: IB Advertising
- Audi How to Check Tire Pressure<br>Step by step instructions for do-it-yourself repairs.
Tire Pressure
I run the max shown on the door sticker (I believe it's 44psi all around). I've ruined too many rims on potholes and want the max protection possible. Ride is a little harder, but once you get used to it it's fine.
In my experience with hitting potholes, the higher the PSI, the less forgiving the tire and the greater chance for a bent wheel or damaged tire.
This is not specific to the the A3 or S3, but the pressure indicated on the door is designed to hold up the weight of the car when fully loaded. If you drive around with a mostly empty car, that means your tires are over-inflated at that pressure and won't make even contact with the road across the whole width of the tire and even suffer from increased wear in the center vs the sides. For driving around mostly empty, you should inflate it to the normal load pressure listed in the user manual.
Please don't patronize me. I read the manual, cover-to-cover. I don't drive around with a mostly empty car; usually 2-3 people. I always get excellent tire wear. The times when I've had wheels destroyed by potholes my tires were not inflated to the full load. The OP asked for folks opinions, and I gave him mine. Thank you.
I also happen to agree with his comments.
