Turning on rear defroster causes radio static
When I turn on the rear defroster in my A3 Quattro (2015) the radio goes to complete static both AM and FM. But otherwise the radio works great. The dealer claims it is due to the tinted windows blocking the antenna. I bought the car used, so don't know who did the original tints, but a tint shop nearby said they haven't heard of this causing a problem.
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
yes the dealer said part of the antenna was in the rear window. I read on a different forum that
"the FM boosters are in the trim around the inside of the rear screen as they use the heated rear screen element to get more signal"
If that is the case wouldn't this not have anything to do with the tint and be a wiring issue in the car? (That the dealer is responsible for fixing under warranty?)
It is not uncommon for the radio to use the rear window defroster as an antenna.
Tint alone has nothing to do with your issue. The signal comes in from the outside so it hits the defroster before it gets to the tint.
The only way your tint could be having any impact - and it would be a stretch, is if it is metallic tint and is creating conductivity across the defroster wires.
Sounds like an easy out for the dealer to me
I can guarantee it has absolutely nothing to do with your window tint it contains nothing metallic thats absolutely absurd. Just blaming it on anything they could to get outta paying to fix the issue. My 2007 A4 has no tint what-so-ever and I have the same issue it's either linked to the antenna/defroster conflict as suggested, or something to do with wires behind the infotainment system conflicting with each other. . I haven't been able to fix the issue yet, but when I do I'll post the fix.
xkahn
02-08-2018 10:43 AM
Audi A8 2005 Audi A8L
Jan_PL_S6
12
11-27-2015 07:27 AM
S4intheOC
09-08-2015 12:12 AM
shabz
A4 (B7 Platform) Discussion
09-05-2015 12:34 PM
