TYRE REPAIR KIT question
I had a very bad luck and after replacing two front tires I have drove on top of a hole on the road and the right tire lost all its air pressure immediately.
Tomorrow I'll go to the tire workshop again but before that I need to use the TYRE REPAIR KIT to put some air in.
According to the manual, I need to connect the compressor to the sealant can and the sealant can to the tire.
Can I try first to connect the compressor directly to the tire? I'm not sure that there's really cut or puncture.
Thanks
Thanks
Try with just air. Once you put in the sealant, I believe the tire cannot be repaired (the sealant ruins the inside) and you have to throw away the tire. Using the sealant is a temporary fix to get you to a service facility. If you use just air you may be able to have the tire repaired.
Update:
It was a very big puncture. No way to repair using the kit. On top of that, the back tire also got damaged from this pot hole.
I've been towed from my home to the service facility. They replaced both tires.
Damage: 850$
Damage: 850$
In my country, all luxury cars (Cars above 80K USD) has no spare tire. Haven't tried to figure that out but I assume that they think that "reach" people will not use the spare tire but will call for assistance? Just an assumption....
