VAG-COM = VCDS?
I'm new to Audi/VW - Just picked up a 2018 S3. I've heard some of you mentioned VagCom for diagnostic and programming, but not exactly sure which specific hardware/software you're referring to? Does VagCom means VCDS? This => https://store.ross-tech.com/shop/vchv2_ent/
I just like to use it for diagnostic and basic programming. For example, setting the exhaust valve to be permanently open as well as disabling auto start/stop.
Thanks.
Thanks.
yes.. VAG-COM is now known as VCDS.. both are synonymous.
Thanks. Does OBD Eleven have long code helper like VCDS? I like to know what exactly that I'm changing so I can revert back if needed. OBD Eleven is nice with its Apps, but that's like coding things blindly and trusting the Apps that it does toggle the correct bit, which may not always be the case. I also like the fact that VCDS will work as a standalone without needing a WiFi connection
Yep, in addition to the apps, OBDeleven also has adaptations and a long coding interface. The only drawback is that you need an Android device. I picked up some cheapo tablet which is complete crap. I would recommend getting a decent device (if you don't already have one of course).
I'd like to see this too, but my guess is if odbeleven is showing you the changes it's making to enable VIM for example, then people aren't going to pay the 100 coins for it.
Ad a tech guy myself that has had problems many times with scripts making changes to the windows registry, I want to know what's going on.
-SlowSilverTIPJason-
VAG-COM Discussion
06-01-2007 05:03 PM
Boston1.8T
02-14-2003 10:03 AM
