Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
Winter Tire Pressure
Old 11-06-2015, 02:25 AM
Squalo's Avatar
Default Winter Tire Pressure
Searched the forum but cannot find a good answer for this.
Just put on my winter setup: 225/50x 17 Blizzaks WS-80s on Andros R9 wheels. My summer setup is 235/35x19-inch summer tires which call for 44 lbs all around for a full load.
My question is: What pressure should I use for the 225/50 17s? 44 lbs seems about right to protect the 235/35 19-inch wheels, but seems too high for the 225/50s
TIA
Old 11-06-2015, 03:07 AM
uberwgn's Avatar
You'll need to see your Owner's Manual for recommendations on small diameter wheels. It's all there!
Old 11-06-2015, 05:55 AM
Fixeroh's Avatar
Former thinking had people using lower tire pressures than recommended during the winter months. Believing lower pressures gave better traction. Current thinking is to set the pressure right at the recommended levels. Better wear on the tires, better mpg, etc. As uberwgn suggested, the manual should indicate the proper pressure for your size tire. Going from a 35 series summer tire to 50 series winter, I imagine the pressure will be in the 32 to 35 psi range.
Old 11-06-2015, 12:14 PM
DennisMitchell's Avatar
I am doing 18" winters on my S3 and I believe I use 34psi.
Old 11-06-2015, 12:46 PM
uberwgn's Avatar
On the earlier European cars I've owned, they typically showed summer pressure + 4 psi. Tire tech has changed a lot. You're good with the recommended pressure found in the Owner's Manual and possibly slightly lower.
mplsbrian
S4 (B9 Platform) Discussion
10
10-23-2018 11:30 AM
Sperhacs
A4 (B9 Platform) Discussion
13
01-31-2018 08:23 PM
tkao2025
12-09-2008 06:21 AM
DanosS4
12-04-2002 09:00 AM
Annville
Wheels & Tires Discussion
11-27-2002 07:11 PM
Quick Reply: Winter Tire Pressure
