Last edit by: IB Advertising
- Audi A3 How to Replace Center Brake Light<br>Step by step instructions for do-it-yourself repairs.
How to replace A3 Center Brake Light?
Trying to replace the A3 center brake light at the top of the hatch, but having difficulty removing the interior molding to access the brake light, or am I going at the entirely wrong? Any ideas?
Thanks
Thanks
Removing and installing high-level brake light
Removing
Caution
t To facilitate removal of high-level brake light it is sufficient to unclip and bend back top edge of trim at top of rear lid only.
t To prevent trim at top of rear lid breaking (it must not have a temperature below 20 °C) use hot air blower to slightly heat up trim at top of rear lid, if necessary. This applies to older vehicles in particular.
– Unclip and bend back trim at top of rear lid at top securing clips → Rep. gr.70.
– Press fasteners -1- together at sides -arrows- using long-nose pliers.
– Press high-level brake light out of rear lid recess starting at right.
– Unplug electrical connector -2-.
NoteThe electrical connector can only be unplugged with high-level brake light removed.
Installing
Install in reverse order, paying attention to the following:
NoteIf the LEDs are defective, the complete high-level brake light must be renewed.
– Pull fasteners -2- in direction of -arrow- to engage them; the spring -1- must be tensioned.
– Plug in electrical connector and insert high-level brake light into recess in rear lid.
– Press high-level brake light into recess until fasteners engage.
– Install trim at top of rear lid → Rep. gr.70.
Removing
Caution
Installing
